Clean/Glue Ensolite walls - Fiberglass RV
Old 04-30-2003, 01:24 PM   #1
What do you use to stick the ensolite back in areas where it is
torn. Closet area has a few rips, and we want to paint it.
Also where in Canada can you get a new oven.
Any help gladly appreciated.
Willma
Old 04-30-2003, 03:21 PM   #2
Re-gluing Ensolite
Liquid Nails (ie Construction Adhesive) worked well for me. You'll have to prop something up against the roof/walls to hold it in place while it dries - but it holds fairly well after that.
For filling the gaps/rips I'd suggest paintable caulk. Works well especially if you're planning on painting the walls somehow. (As posted elsewhere) I hit mine with spray vinyl which blended the caulked-in seams very well.
mkw
Old 04-30-2003, 03:28 PM   #3
photos
Here's some shots of my insulation being repaired:
Insulation down:
<img src=http://www.fiberglassrv.com/board/uploads/3eb03efeb07a0image5.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3eb03f091bcf0image9.jpg/>
Propped up while the glue dries:
<img src=http://www.fiberglassrv.com/board/uploads/3eb03f53e84cdimage4.jpg/>
spray vinyl before/after shot:
<img src=http://www.fiberglassrv.com/board/uploads/3eb03f9cbe28cimage18.jpg/>
Interior afterwards:
<img src=http://www.fiberglassrv.com/board/uploads/3eb03fc298082image23.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3eb03fd8d0bc1image24.jpg/>
There-ya-go...
mkw
Old 04-30-2003, 04:06 PM   #4
Hi Wilma
I think Mike gave you all the good answeres.I followed same proceedure and only diference was that I used Melimaine Paint and a small foam roller along with a tiny paint brush.Hope this helps.;)
Old 04-30-2003, 04:14 PM   #5
Glue/Ensolite
<img src=http://www.fiberglassrv.com/board/uploads/3eb04a3f92af8rv.jpg/>
Thanks, heading into the city to pick up paint etc etc.
Yours looks great, we don't have to do that amount,
mostly where the cushions rubbed it. Used your pic to show where.
Trying to decide what to do there.
Willma
Old 04-30-2003, 04:19 PM   #6
Hi Wilma
I didn't have wear ,where cussions sat.I had wear under the front table at front end of unit from being kicked or from shoes.I filled it in with plywood and painted.On seat I don't know what to tell you.Maybe someone else has had that problem and fixed it.:)
Old 04-30-2003, 04:30 PM   #7
Glue/Ensolite
Thanks as well Chester, going to use the melamine paint as well.
Once you get the beast home they show all the little owies they
have been hiding. Nothing major but still need to be taken care of.
We have a piece in front of the table that is used to protect it so maybe we can use the same type and place it on the side to stop the
wear. I noticed you used the laminate flooring, that stuff is great.
We have in in our house and cleans very well.
<img src=http://www.fiberglassrv.com/board/uploads/3eb04e7785a43rubbed.JPG/>
You can see the area under the window by cushion
Willma.
Old 04-30-2003, 09:35 PM   #8
check to make sure the window is not leaking. that's the first thing that comes to mind when I see stains under the windows. drain is plugged. or caulkings cracked, or both. Course if it's cut or worn off then that's another story. :)
How much scrubbing to get that ensolite clean? Isaac M Modifications, Alterations and Updates 16 04-27-2013 08:41 PM
Making Curtains with Glue Gun Pamela S. Problem Solving | Owners Helping Owners 3 04-14-2010 07:38 PM
How to glue ensolite back on Barry Konkin Problem Solving | Owners Helping Owners 10 02-02-2009 02:59 PM
removing glue colleenz Problem Solving | Owners Helping Owners 11 10-05-2007 08:03 AM
spray glue trouble JIMZ Problem Solving | Owners Helping Owners 7 05-25-2006 10:49 AM
