Cog wheel replacement? Surfside - Fiberglass RV
Old 05-10-2015, 06:27 PM   #1
hudman's Avatar
Trailer: triple e
Hello everyone,
I'm now installing the windows in my surfside and noticed one of the windows doesn't close properly. After taking it apart, the cog 'half' wheel is stripped I one portion effectively not allowing it to close nice and tight.
Anyone come across this and have any idea where I could order this part or will I be duct taping this closed on road trips?
Thanks.Click image for larger version
Name:	ImageUploadedByFiberglass RV1431303977.122753.jpg
ID:	83820Click image for larger version
Name:	ImageUploadedByFiberglass RV1431303997.127300.jpg
hudman is offline   Reply With Quote
Old 05-10-2015, 08:15 PM   #2
Do you mean the "window operator", the little gearbox part that cranks out the window. There are a few different types. Vintage trailer supply in Vermont has some. I found one at an Ace hardware store that I made work on a vintage camper window
mary and bob is online now   Reply With Quote
Old 05-10-2015, 09:04 PM   #3
hudman's Avatar
Trailer: triple e
Yes, I believe that's what I'm looking for. I'll attach another couple of pics of the actual cog. I'll give your place a call tomorrow morning. Thanks for the help!Click image for larger version
Name:	ImageUploadedByFiberglass RV1431313412.133644.jpg
ID:	83838Click image for larger version
Name:	ImageUploadedByFiberglass RV1431313427.016058.jpg
ID:	83839Click image for larger version
Name:	ImageUploadedByFiberglass RV1431313438.815234.jpg
Old 05-10-2015, 10:47 PM   #4
Borrego Dave's Avatar
Trailer: Casita SD17 2006
James, I don't have those but it looks like it's a circle cog. Any chance of rotating it 180* so that you have good teeth in the closed position for a tight fit for travel? Kind of a temporary fix until you can find a new wheel.
Old 05-11-2015, 05:55 AM   #5
Look at the window operator pictures on Vintage Trailer Supply website. The "cog wheel" on those is most likely enclosed and not visible. Perhaps you can adapt one to work on your window. May have to make a spacer or shim
Old 05-11-2015, 07:37 AM   #6
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
I replaced all the cranks in my 1977 Surfside with new ones which came from the original window manufacturer Berdick Windows in Winkler Manitoba , the cost was about $7 each , hard to install but sure work great.
Bob in Mb is offline   Reply With Quote
Old 05-11-2015, 07:52 AM   #7
hudman's Avatar
Trailer: triple e
Thanks dave- i was thinking that but it's actually only 'cogged' on just over half the wheel. The full reno isn't quite done yet so I have some time to order one in before use.
Old 05-11-2015, 07:52 AM   #8
hudman's Avatar
Trailer: triple e
Yeah I found the correct replacement on that site. Thanks very much for the advice 😀
Old 05-11-2015, 07:57 AM   #9
hudman's Avatar
Trailer: triple e
I'll give them a call today as it might be cheaper than ordering from the USA. Thanks to everyone for the help😀
Old 05-12-2015, 09:10 PM   #10
hudman's Avatar
Trailer: triple e
They have a few of these left at the place quoted above...two arriving in a few days....thanks Dave and everyone else for your help!
Old 05-19-2015, 04:56 PM   #11
jrocmagoo's Avatar
Trailer: 1978 Tripple E Surfside
wow my back windows are the same deal! i may have to check this supplier out! it pays to read these threads!
jrocmagoo is offline   Reply With Quote
Old 05-19-2015, 05:48 PM   #12
hudman's Avatar
Trailer: triple e
So berdict windows has the originals for 11 bucks CAD. Vintage trailer supply has the replacement for 8 bucks...either will work fine depending on where you live. Ordered mine today!
surfside
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Wheel bearing replacement ericw Care and Feeding of Molded Fiberglass Trailers 71 08-24-2014 10:16 AM
Inverter plastic switch thingamajig replacement - Surfside Shelley Problem Solving | Owners Helping Owners 1 07-09-2013 06:40 PM
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
Scamp Trailer Crank Wheel/No Wheel Mitchell Problem Solving | Owners Helping Owners 6 08-25-2008 11:36 AM
