I have an old Norcold DE-704 I am going to install in my 16" Scamp. The thing works, but was noisy with the swing motor compressor. I got new vibration absorbing runner mounts and that helped a lot.
The next thing it to improve the efficiency of the unit. It doesn't use but 40 watts AC or DC, but it would help if it worked better.
last night I tried using soft aluminum tape stuck to the heat heat exchanger on the back to give the thing more surface area. It seemed to help.
Tonight I am going to work on a little different method to install the tape and get good thermal conduction.
Here is an article from 3m on using the tape for the inner coil during manufacture
*Â*Maximize Cooling Efficiency of Refrigerators
Here is a demonstration video:
I plan to put the tape between the small steel rods that run vertically and are welded to the main coil to make lots of fins to transfer the heat away from the coils. this should dramatically increase the heat transfer on the hot coil.
First I tried just wrapping some aluminum tape over the small wires joining the coils like this
Then I added some tape folded back on itself leaving part of the sticky to attach to the base already installed. It is a little hard to see.
A picture from the top
It looks a little messy, but the idea is to add surface area to help get rid of the heat from the compresor. I don't yet know if it helps, but the compressor is quieter. Doing this a little neater with the added fins would help any
refrigerator be more efficient and use less power and keep the insides cooler. Cycle time would be shorter.
Painting it flat black would probably help as well.
