Computer power supply in my Boler - Fiberglass RV
Old 09-13-2008, 06:45 PM   #1
Trailer: 13 ft Boler ('Le Porto II') / 2006 Pontiac Torrent
I just thought id share my idea. I had an old power supply that i took out from a desktop computer. There are 4 different outputs on it. 12V 7.5A, 12V .3A, 5V 3A and 5V .2A. I opened it, cancelled all the outputs except for the 12V 7.5A and installed it in my Boler to run the lights, fan, and radio. So far it works great. Of course the fan is always running on it but ill install a switch to go from the converter to the battery at night when i only have to use a light or 2. I wont use it to charge the battery, as that will be done from a solar panel or when im on the road. Ill update next summer when im done restorating Porto II.
Dominique is offline   Reply With Quote
Old 01-21-2015, 11:04 PM   #2
Trailer: Boler 13
Desktop computer power
Interesting idea.
How's it been working since 2008?
jim
using 12v computer fans to move air around our Boler 13 ...
Jim Pissot is offline   Reply With Quote
Old 01-25-2015, 07:36 PM   #3
Dudley's Avatar
Trailer: 1998 Casita 17 SD
Now for a killer power supply, I have been using a HP DPS-1200FB which is a small server power supply that puts out a whopping 75 amps at 12vdc(can be adjusted up to around 13.8 volts). I use it to power my LiPo battery chargers for my RC plane batteries. These supplies are designed to run 24/7 for years. All it takes to get them running is a 500ohm to 1k ohm resistor( this can be used to switch on/off with a single pole switch)
HP power supply
boler
Vintage Trailer Supply Cam A Care and Feeding of Molded Fiberglass Trailers 5 08-02-2007 09:01 PM
Water supply when there's no water supply Dave M Plumbing | Systems and Fixtures 18 06-06-2006 10:00 PM
Power Supply Questions Patricia Baxter Modifications, Alterations and Updates 14 05-20-2006 09:45 AM
Power supply Harvey Craft Problem Solving | Owners Helping Owners 5 04-10-2006 08:51 AM
Computer power on the road Legacy Posts Problem Solving | Owners Helping Owners 8 04-03-2003 05:17 PM
