Converting dinette into a "U" with more accessible storage. - Page 3 - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Modifications, Alterations and Updates
Click Here to Login
Old 10-26-2008, 05:52 PM   #41
Trailer: 1991 17 ft Horizon
I just might have to make one of those sliding tables myself, thanks for the pics.
Old 10-29-2008, 07:54 AM   #42
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
what are you doing with the old lights Peter?
Scott S. is offline   Reply With Quote
Old 10-29-2008, 08:02 AM   #43
Scott S.'s Avatar
you must be one of those ppl that wakes up in the middle of the night and has to keep a note pad by the bed to empty your brain onto so you can get back to sleep? Scamp should have you on their design dept. payrole. bravo!
Old 10-29-2008, 09:42 PM   #44
peterh's Avatar
We had six of the original Scamp lights and gave a few away to some friends. The rest we are keeping until we either install them in our Surfside trailer project or decide we want some other kind of lights there. That'll be a while off; we plan on starting work on the Surfside next year after I complete the remaining "big ticket" projects in the Scamp 5er.
Old 10-30-2008, 08:13 AM   #45
Scott S.'s Avatar
thanx Peter. I did find one on the internet to order.
I'm going to keep looking to see if I can find a more modern looking one tho.
I only need one so I may also go for a socket conversion.
Old 10-30-2008, 11:25 PM   #46
peterh's Avatar
I think there'll be 1156 warm white bayonet base LED "bulbs" out soon. That would simplify converting them to LEDs.
Old 03-16-2009, 01:43 AM   #47
peterh's Avatar
I just finished adding a "backlight" to our fresh water tank. If you followed this topic you might remember I installed a "thermometer-like" viewing window in the face of one of our dinette benches so you could see the water level in the fresh water tank under the bench seats. The idea didn't work out as well as I had planned -- there wasn't enough light in the tank to see the water in the tank.
This weekend I added an LED light strip that "backlights" the tank when I push a button next to our water pump switch. Now I can see the water level really, really well!
I used a hot-melt glue gun to mount this 2-watt red LED light strip to the bottom edge of a scrap of pressboard (on the bottom edge so the light comes up through the water instead of shining down on it) and duct-taped the panel to the back of the water tank opposite the "thermometer" viewing window.
Now I can see my fresh tank water level at the push of a button!
Old 03-17-2009, 08:32 AM   #48
Steve Hilby's Avatar
Trailer: Compact Jr
Now that's a clever idea!
Steve Hilby is offline   Reply With Quote
Old 03-19-2009, 01:36 AM   #49
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
....... duct-taped the panel to the back of the water tank opposite the "thermometer" viewing window....
is the LED light panel running horzontal or verticle on the back side of the tank. If Horzontal.. are you saying you put light along the bottom edge of back side of the tank?
Coach George Jessup is offline   Reply With Quote
Old 03-19-2009, 12:49 PM   #50
Roger C H's Avatar
Talking
Pete,
Interesting mod. I notice that you have tubes and wires going through holes in bulkheads. Please tell me that you grommeted all these locations to prevent the bulkhead from wearing holes in the tubes/wire insulation.
Old 03-19-2009, 04:13 PM   #51
peterh's Avatar
It's mounted horizontally to illuminate the bottom-most back edge of the tank. I did it that way so that the light gets trapped in the water, forcing it to act something like a fiber-optic cable and illuminate the front of the tank where the water is much better than further on up the tank wall where the water is not. If you ran it vertically you'd illuminate the "thermometer" viewing window much more evenly.
Old 03-19-2009, 04:19 PM   #52
peterh's Avatar
That's a good point. No, they're not grommeted, but the wire and piping is zip-tied into a tight bundle that runs through the center of the over-sized hole.
Old 05-24-2009, 03:34 PM   #53
peterh's Avatar
This week new upper cabinets made of 1/4" birch plywood with pine and hemlock framing replaced the smaller & heavier cabinets from Scamp. The new cabinets weigh 4 pounds each without their doors; the old cabinets weighed 7-1/2 pounds each. The new doors are bigger than the old so they weigh only slightly less . . . but the best thing about them is the larger door openings make it easier to get things in and out of the cabinet.
From this
Yet to be decided is last "big" change inside our trailer, which is possibly adding a shelf or cabinet over the back window to span the distance between the two new white cabinets over the dinette.
Old 06-22-2009, 11:46 PM   #54
peterh's Avatar
The last cabinet I'm building for out 5er is taking shape. This one spans the back of the trailer between the two left and right upper cabinets I installed last month.
The center opening is designed so it'll fit a board game and will have a traditional door like the ones I made for our other cabinets. The smaller side cabinets are going to be more challenging. They're meant to be open storage cubbies that Lynne and I can easily reach up to while sitting in the dinette without having to open or close a door, but we still need a way to close the cubbies off so their contents don't spill out while we're towing. A standard swing-type door won't work here, though, because it would block the swing doors on the side cabinets.
So I'm making an oak "roll" door, like you find on a roll-top desk. That way we can keep the cubbies open when we're camping without blocking the swing-up doors of the side cabinets but still close the cabinets off for towing (or to hide the mess inside).
Old 06-23-2009, 05:06 AM   #55
Don N's Avatar
Trailer: 1978 Boler 1700
Excellent idea with the "roller" doors. Will also look very appealing when they are closed.
Don N is offline   Reply With Quote
Old 06-27-2009, 02:56 PM   #56
peterh's Avatar
The new dinette upper cabinet with its swing-up and roll-up doors. I still need to make a curtain rod.
Roll-up doors Closed:
Open:
(Sorry about the lousy view out the back window: Our trailer is parked at the storage yard right now.
Old 06-27-2009, 06:11 PM   #57
Here I thought you had TWO trailers now.
Bill K
Old 06-27-2009, 07:23 PM   #58
Bill K
He does have two trailers Bill, just not that sticky you see through the window. Peter and Lynn bought a Surfside last year: Inaugural trip of a new-to-us Surfside If the 5er is any indication, Peter has some fine, fine mods going through his head for the Surfside
Old 06-27-2009, 08:28 PM   #59
Talking
So I'm making an oak [b]"roll" door, like you find on a roll-top desk.
Class, today's vocabulary lesson is:
Tambour Door.
Old 06-08-2012, 07:04 AM   #60
Trailer: Casita SD 17 - 1998
Thanks for all the great ideas!
Garth is offline   Reply With Quote
2010 Custom Fiberglass teardrop"Real Kool" Dave Baston Referrals: Molded Fiberglass Trailers 1 06-07-2010 05:14 PM
SOLD - 1970 Boler on "Ebay" 10 hours/ 20 Minutes left Dave Baston Classified Archives 5 04-12-2009 10:45 AM
INFO RE Fiberglass "Travel Lite" Trailers of Early 60s Don Cordier General Chat 4 07-23-2008 11:18 AM
