Converting front bunk in Boler - Fiberglass RV
Old 05-26-2016, 06:45 PM   #1
Keaner's Avatar
Trailer: 1973 13' Boler
Hi folks. I've decided I'm going to convert my front bench into two small seats separated by a small table. Has anyone tried this?
Cheers
Keaner is offline   Reply With Quote
Old 05-26-2016, 06:55 PM   #2
Roy in TO's Avatar
A number have done this. I see you have a 1973. You may find that there is a straight 6" step across the front under the bench. I forget when they started putting a notch in the step. The ones with the notch for the "port a pottie" are an easier mod.
Old 05-26-2016, 07:54 PM   #3
Keaner's Avatar
Mine has the straight step. I am wondering if I should cut out a section of the bench and patch it or remove it all together and build from scratch.
Old 05-26-2016, 08:04 PM   #4
Roy in TO's Avatar
That gets my vote. That way you or someone else can always restore to original. The front dinette mod does not work as well when you have the step across the entire width of the trailer.
Remember that the bench adds structural support to the body. Whatever you do, try to tie into the "plywood tab" on the walls that the bench screws into.
Old 05-27-2016, 08:51 AM   #5
bullfrogeh's Avatar
Hi Joe and Roy - I'm in the 'same boat', with an uncut 1973 Boler front bunk floor. I've decided that by just raising the two proposed seats a couple of inches, I wouldn't have to consider the structural element of butchering the bunk floor at all. Why not have a slight step-up to the new 'dining booth' ? We're even considering building in a porta-potty beneath the new street-side seat of the 'dining-booth'. Any further thoughts on our proposal ?
bullfrogeh is offline   Reply With Quote
Old 05-27-2016, 09:12 AM   #6
Johnny M's Avatar
Deep South
My 71 has the cutout, we put a bath in the front turning the bunk 90 degrees removing the kitchenette...have fun with your project
Old 05-27-2016, 09:35 AM   #7
Keaner's Avatar
I think this is the way to go. Rather than a porta potty I am going to install a small beer fridge.
Old 05-27-2016, 09:46 AM   #8
Trailer: 73 Trillum 98 Scamp 16ft. 2007 Escape 17ft.
front bunk /table
We upgraded to to a 16ft Scamp this year which has a front bunk. The bath takes up a lot of space so instead of cutting out the bunk I added a table that is easily removed that you sit sideways at. The table top slides from one side to side allowing easy access. I used a 2x4 galv. bracket bolted to the front of the bunk for the leg and then covered it with the same 1/2 inch birch plywood. The 2x4 leg fits snug in the 2 brackets, a small wood wedge makes it tight. Only 2 trips so far and we are happy with the results. Nothing lost still have bunk beds for the grandkids. Hope this maybe helpful to someone. John T
JT33 is offline   Reply With Quote
Old 05-27-2016, 11:10 AM   #9
Keaner's Avatar
Sweet! Nice work JT.
Old 05-27-2016, 02:18 PM   #10
Timber Wolf's Avatar
North Florida
Whenever my daughter gets around to kicking Dad to the curb I am going to do the front dinette mod to my Scamp. JT's mod is pretty sweet though, thanks for the tip.
Old 05-27-2016, 02:46 PM   #11
Johnny M's Avatar
Deep South
Nice mod I like it!
Old 05-28-2016, 08:06 AM   #12
bullfrogeh's Avatar
Wow ! Great ideas come out. I really like JohnT's sliding table top. It preserves the 'bunk' option, and makes very flexible use of the new dinette creation. And, I believe it could also 'seat' more than two if the table insert is optionally inserted by 180 degrees, to provide 'bench seating'. Hhhmmm ? - Now, to rethink that alternate kitchenette relocation, and the 'brown-jug' fridge !!! Thanx team - I Luv the ideas that float out of these forum threads.
Old 05-28-2016, 09:28 AM   #13
I looked for a picture but couldn't find one of someone's front bunk conversion. They removed everything and then used two office chairs from Costco. They took off the wheels and bolted the chairs straight to the floor. Then put a table inbetween. Looked pretty good after and probably easier to get into a swiveling chair than sliding in past the dinette. If you google "boler front bunk conversion" it brings up a few different options people went with too. Can't wait to see the before and after pics!!
TimR is offline   Reply With Quote
Old 05-28-2016, 09:30 AM   #14
I have tried a few things for a table at the front sofa (without doing a major remod).. One is this table. I can open the porta-potty door and slide the legs in (on either side of a storage box I have in there). It works but is not perfect. Its easy to dislodge the support bar and have the table drop unexpectedly. The cup holder will not swing out because the bathroom is in the way (Scamp layout four). I use it sometimes.
The other thing I do is keep a few storage boxes with flat tops on the sofa's port side. The tops are flat and make a serviceable side table, and they are dual purpose which I like. The same boxes fit under the dinette when in bed config so they can go there if I want the entire sofa (as a bunk for example).
I might do the front dinette conversion some day, but for me, at present I think these methods work OK and are the easiest thing to do.
boler
Converting Bigfoot Upper Bunk to Shelving ZachO Modifications, Alterations and Updates 10 01-15-2017 08:58 AM
Converting non Bunk to a Bunk arrangement Trillium-Pettis Modifications, Alterations and Updates 2 05-29-2015 08:49 AM
Converting 16' Scamp front bathroom to easy access storage chuyler1 Modifications, Alterations and Updates 10 05-20-2015 02:10 PM
For Sale: Referral - Trillium 4500 front bunk, double bunk and awning David Tilston Parts: Buy | Sell | Trade 6 02-26-2014 05:30 PM
Converting a 13' Boler to a tandem axel Dominique Towing, Hitching, Axles and Running Gear 7 08-18-2008 05:52 PM
