Converting non Bunk to a Bunk arrangement - Fiberglass RV
Old 05-28-2015, 05:08 PM   #1
My 1975 Trillium did not originally come with a top bunk but I want to add one.
So I have :
fabricated the top bunk ( board, cushion and cover)
Purchased 2 correct poles
modified the lower couch to receive the poles
Bought the hinge
Now come my questions:
What else ?
Do I simoly add a pc of wood to the lower windowsill , 2 pcs of wood to support the safety bar and.... done ?
Am I missing something ?
Trillium-Pettis is offline   Reply With Quote
Old 05-28-2015, 05:12 PM   #2
It is a Trillium 1300 (1975)
Old 05-29-2015, 08:49 AM   #3
David Tilston's Avatar
There should have been two dimples in the top of the lower bunk to receive the support poles. What modifications did you make?
The stock arraignment has a strip of plywood screwed into the bottom of the front window frame, the the piano hinge for the bunk is screwed into that strip. I think that the point of the plywood strip is that it allows the use of longer screws to hold the bunk.
When the bunk is up, two poles are inserted between the previously mentioned dimples in the upper surface of the lower bunk, and shower curtain rod brackets installed on the bottom of the upper bunk.
want different sleeping and eating arrangement gregd Problem Solving | Owners Helping Owners 2 12-30-2011 07:54 AM
converting 12 Volts to AC with a Used UPS ? Marty Smiltneek Modifications, Alterations and Updates 3 07-17-2009 02:38 PM
Converting Rust? Ed Harris Problem Solving | Owners Helping Owners 3 10-06-2008 01:49 PM
Converting a 13' Boler to a tandem axel Dominique Towing, Hitching, Axles and Running Gear 7 08-18-2008 05:52 PM
Converting old plexiglass into new sun shade VIDEO kevin61 Modifications, Alterations and Updates 6 07-28-2008 07:46 AM
