Cool! - Page 2 - Fiberglass RV
Old 02-27-2013, 09:54 PM   #15
David Tilston's Avatar
Originally Posted by Brian B-P View Post
David, that's a fascinating piece in that roof; I agree it looks like a raised section to maintain headroom under the air conditioner, and it may also serve as a reinforced "bridge" across the roof. I think you'll find that the air conditioner itself is installed through a typical 14" square hole in the raised section.
Based on this thread, I think you are correct.
A/C Roof Parts
Old 02-28-2013, 07:29 PM   #16
Gina D.'s Avatar
West Coast USA
Nice job Fred!..and oddly enough, for some insane reason this morning, I thought about when I pushed the Big Burro up that ramp!
Old 02-28-2013, 08:00 PM   #17
Luis's Avatar
Trailer: Boler 1300 79'
I liked your US map with States visited decals, if my guess is correct...
Cheers,
L
No need for A/C in my side of the woods...
Luis is offline   Reply With Quote
Old 02-28-2013, 08:18 PM   #18
calindor's Avatar
Trailer: 19' 1977 BIGGAR
Lookin' good, Frederick!!!
1977 19ft Biggar
calindor is offline   Reply With Quote
Old 03-11-2013, 10:13 PM   #19
Trailer: Fiber Stream
Cool Air Conditioning and a Fantastic Fan
Originally Posted by Frederick L. Simson View Post
I removed my Fantastic Fan to install the A/C.
Now I need to cut a new 14" x 14" hole to reinstall the Fantastic Fan in front of the A/C.
I measured and marked the new location. Then I drilled 3/8" holes in the corners. Used a jig saw to "connect the dots." Since the Fiber Stream is un-insulated, all I have is about 1/8" of fiberglass to cut through. From my scrap materials bin I found some leftover pieces of Trex and milled it on the table saw. I used Butyl tape to attach the Trex frame to the top of the 14" x 14" hole. A stained wood frame was Butyl taped to the underside of the hole and the two frames were drilled through the fiberglass and screwed together from the inside. I then installed the Fantastic Fan to the top of the Trex frame with more Butyl tape and screwed it down. Then I finished the job by caulking with DAP DYNAFLEX 230 Premium Indoor/Outdoor Sealant and then reinstalled the cover over the Fantastic Fan.
Old 03-11-2013, 10:29 PM   #20
Inside
BEFOREClick image for larger version
The Fantastic Fan is centered in the trailer. Note the gray conduit that brings the 12 volt wires from the kitchen wall to the fan.
The Air Conditioner replaces the Fantastic Fan. The gray conduit remains and a new cord is zip-tied to anchors glued to the ceiling to bring 12 volts from the AC enclosure to the new Fantastic Fan location. 110 volts is brought from the outlet inside the top of the Pantry/Refrigerator cabinet on the other side of the AC enclosure.
The Air Conditioner and Fantastic Fan as seen from the kitchen area.
Cool Stuff for the Cool Camper brian m. Commercial Posts and Products 64 01-26-2015 10:08 AM
Also not FG, but cool Bobbie Mayer General Chat 3 03-06-2010 10:50 PM
This is VERY cool Kevin K General Chat 3 01-09-2010 09:14 AM
Not a FG, but OH SO COOL! V'sGlassSleeper General Chat 10 08-27-2007 09:44 PM
This is cool Thomas Haney Modifications, Alterations and Updates 4 05-10-2007 08:49 AM
