Before mounting directly to a
fiberglass roof I would measure the top and bottom temperatures of the panel on a relatively hot day while it is generating the max amount of electricity.
Fiberglass isn't a good thermal conductor so the heat buildup under the panel will radiate into the roof insulation and over time may cause problems to the interior under the panel. Aluminum is an excellent thermal conductor and will easily dissipate the heat buildup so tests done on Airstream trailers may not be valid on a
fiberglass unit.
I am thinking about making a removable
solar panel sun
awning out of pvc or aluminum angle and designing it so it could attach to the back or rear side
windows or just sit out somewhere in the sun.
