Crimping Battery Cable Lugs - Page 2 - Fiberglass RV
Old 09-27-2010, 10:00 PM   #15
Originally Posted by Carl G View Post
My error - I am using 4 AWG wire, not 4/0. Sorry for the confusion. This is the minimum gauge I need to avoid problems with voltage drop between the converter/charger and the battery.
I would suggest that you really look at voltage drops vs length vs wire size. The difference between 4 AWG and 10 or 12 AWG I doubt is worth the difference in cost.
I just made the calculations for you 4 AWG with 10' wire you'll drop about 50 milivolts. 12 AWG about 300 milivolts. With 10 AWG it about 100 milivolts.
Not worth the additional cost. That's assuming a 20 amp current flow. I doubt you ever get more than 4 amps flowing between the converter and the battery so you can divide those number by 5 to a more realistic voltage drop.
Absolutely nothing in your trailer is that sensitive to voltage drops.
Byron
battery
Breakaway cable; are Bargman's all the same? paulitzlee2 Towing, Hitching, Axles and Running Gear 0 07-08-2010 07:31 PM
14" Rims with 4 lugs ?? Phillip Towing, Hitching, Axles and Running Gear 2 07-06-2009 10:00 PM
Cable hook up Lenna F Problem Solving | Owners Helping Owners 11 05-26-2008 03:51 PM
television cable Legacy Posts Modifications, Alterations and Updates 6 03-31-2003 12:32 AM
Cable Access Legacy Posts Problem Solving | Owners Helping Owners 4 12-04-2002 03:32 PM
