Ct 13 back window suggestions - Fiberglass RV
Old 04-30-2013, 06:52 PM   #1
uhaulin's Avatar
Trailer: Uhaul ct-13
I a have searched and read different things but I like current answers that are directed towards me. I am in need of a back window for my uhaul. What are my options? My last option in the world would be to rebuild because the amount of silicone on it overwhelms me and I want no part of it. My time could be spent camping rather than scraping a window for the next 4 weekends. Any suggestions of what you know works in its place?
uhaulin is offline   Reply With Quote
Old 04-30-2013, 06:55 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Bob installed a Scamp window.
Someone here found a reasonable source for custom made windows and had a side window made. That same source might make you a rear window. Teardrop Trailer Parts
Please don't toss the silicone infested old window, someone would appreciate getting it.
Old 04-30-2013, 07:01 PM   #3
uhaulin's Avatar
The scamp window did it fit with modifications? Or does it simply fit?
Old 04-30-2013, 07:03 PM   #4
Thomas G.'s Avatar
Bob will probably be along shortly to fill you in, but as I recall he had to enlarge the opening. It should be easy to find it with a search - he has posted about it several times.
Here: Putting Scamp window in Uhaul CT13
Pictures of Uhaul interior and new Scamp windows
Old 04-30-2013, 07:07 PM   #5
I bought a rear window from Scamp and installed it in our Uhaul. The opening had to be widened by about 1/2" on each side. The window cost about $150 plus shipping. I requested that they send me the clamp ring too, but that may be included anyway. The clamp ring had to be put on backwards because of the thin wall of the Uhaul. If you decide to go this route, DO NOT use the weatherstrip that they send with the window, it will not allow the window to set tight against the outside wall and it will leak. I found this out the hard way. Another Uhaul owner here installed a Scamp rear window too, but now I forget who it was. If you need, I'll give you my phone number. Sorry, I don't have any side window weatherstrip left, I gave away or sold the excess. Bob
Old 04-30-2013, 07:10 PM   #6
I don't mind repeating info, because without Tom posting a link, I don't have much luck doing a search. Now I'm trying to find Toms " fearing Canadians" thread
Old 04-30-2013, 07:15 PM   #7
Thomas G.'s Avatar
Originally Posted by mary and bob View Post
....... Now I'm trying to find Toms " fearing Canadians" thread
Canadians: Should I fear them?
Old 04-30-2013, 07:40 PM   #8
Forgot to mention on the Scamp window installation to use the black butyl tape when I said to not use Scamps foam tape. There is a difference between plain putty tape and butyl tape. I've found both at a RV dealer.
Old 04-30-2013, 08:00 PM   #9
uhaulin's Avatar
Thanks Thomas. thanks Bob. I really appreciate the input. Overall bob how happy are you with how the window turned out?
Old 04-30-2013, 08:18 PM   #10
CindyL's Avatar
Illinois
You know, a couple of Uhauls are going to camp during the Mesick, MI mushroom fest. We can't fix your window, but we can help you feel bad about the silicon.
CindyL
CindyL is offline   Reply With Quote
Old 04-30-2013, 08:27 PM   #11
uhaulin's Avatar
When is the mushroom fest.
Old 04-30-2013, 08:47 PM   #12
I'm very happy with the window results. When we got our Uhaul the rear window had been replaced with plexiglass and was all gobbed up with silicone and couldn't be opened. No screen either. Scamp sent some foam sticky tape with the windows, and I figured that if they use it, then it must work. I couldn't get the window lip drawn in tight against the outer wall and it leaked, so I had to pull the window out and reinstall it using butyl tape. That solved the leaking problem. The inside may look a little odd with the clamp ring on backwards, but the curtain covers most of it, and who's going to notice anyway. The Scamp window is a slider with screen, made by Hehr, so it's a good window. I took my time marking and enlarging the wall opening so I got a nice snug fit, and tightened the screws a little at a time, then retightened them again a couple days later. I don't think I used the screws that came with the window, you have to be careful with the screw length so they don't go through the outside frame. Before those NOS windows became available I had installed a Scamp jalousie type window in the right side, but because it is too small for the opening I had to make an adapter piece of 1/8" aluminum. This worked out OK, but I wouldn't recommend that anyone else try it since member Higginra found a source of custom sized clamp ring type windows at a real good price. I did get a pair of the NOS windows and installed one in the left side. If that is what you are doing be sure to seal up those two 1/8" drilled holes at the top of the frame as the AS1456 weatherstrip doesn't cover them. Afterthought: I may also have had to grind down the shell seam ridge a little where the rear window flange sets against the outside, also had to round out the corners a little too. I did the cutting with an air powered die grinder with a thin 2" cut off disc, and the sanding with the same die grinder with 2" sanding disc on it. It was so much easier, and better too, in my opinion, to install new windows rather than try to repair the old ones.
Old 05-01-2013, 03:38 AM   #13
CindyL's Avatar
Illinois
The mushroom fest is May 10-12. See this thread: Mesick Mushroom Festival in Michigan
CindyL
Old 05-01-2013, 05:42 AM   #14
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
For the mushroom festival, the small group of us is camping at the Northern Exposure Campground, sites 46-49.
Scamp back window and maxxair window vent SharonM Problem Solving | Owners Helping Owners 3 04-19-2013 11:06 PM
Cannot open back window in our U-Haul 1985 CT pktajensen Problem Solving | Owners Helping Owners 16 10-18-2012 03:55 PM
Back window seal of a boler bkboler Problem Solving | Owners Helping Owners 8 08-23-2012 10:01 AM
Rebedding Burro back window rabbit Care and Feeding of Molded Fiberglass Trailers 2 08-22-2012 08:44 AM
Taking on the Back Window.... trilliumdon Problem Solving | Owners Helping Owners 2 05-11-2011 08:51 PM
» Trailer Showcase
Ferb
OR335d
Scamp
barcode
