Curtian Rod upgrade for scamp - Fiberglass RV
Old 07-06-2014, 11:20 AM   #1
Trailer: 13' scamp
While preping to paint my scamp this summer ( which is now done) I filled in all the previous curtian rod mounting brackets, cause I did not like that many rivets going through the shell.
Made a frame of wood around the door window and made some thin aluminum brackets to hold a 3/8 delrin rod. ( delrin is a plastic that is light weight and strong)
For the big windows on the ends I made some blocks that were kind of parallogram shape which allowed them to mount pretty close to the window molding. these brackets were mounted on the overhead with a 8-32 screw holding them on. these were mounted about two inches either side of the window rubber, Found out that I had to cut the 5/8s delrin rod in half lengthwise to be able to insert it. This then required a small screw in the end blocks to hold the rod in position.
For the two side windows I hung one end under the overhead like the front/back curtians and then mounted a small block to the closet side and another to the overhead above the sink, both being in line with the top of the side windows. A screw( Pin ) in the front edge of both side blocks allows the rod to be removed if necessary. Here I used 1/2 delrin rod.
I do have lots more pics which will help in understanding this and seeing how good they look but I dont know how to load them into this thread. If anyone knows or wishes to see more pics let me know and I will email you the pict and you can upload them for me.
Red Fox is offline   Reply With Quote
Old 07-06-2014, 12:21 PM   #2
Andrew Morris's Avatar
Trailer: Scamp 16'
Very innovative solution Bob! I believe that you can post more pics by simply posting another comment to this discussion. I would love to see more shots of what you have done...!
Andrew & Allison
Andrew Morris is offline   Reply With Quote
Old 07-06-2014, 12:29 PM   #3
Trailer: 13' scamp
curtian rod upgrade cont'd
More pictures I hope..
Old 07-06-2014, 01:05 PM   #4
Nice, really nice! I agree. To poke that many holes through the shell to hang curtains is just plain nutz! You came up with a good, workable solution.
Old 07-06-2014, 02:31 PM   #5
honda03842's Avatar
Name: Norm and Ginny
Nice job Bob. The aluminum window frame is truly useful. We use them for support of our overhead, never considered replacing the brackets, great idea.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
closet rod for 1985 scamp sugermc Problem Solving | Owners Helping Owners 2 03-05-2012 03:55 PM
Replacing Water Heater rod Karalyn Problem Solving | Owners Helping Owners 9 06-13-2009 12:06 PM
Hott Rod install in Atwood 6 Gal Water Heater Michael Pupeza Modifications, Alterations and Updates 3 04-27-2009 09:14 AM
Keeping the hangers on the rod in the hanging closet Kent I Problem Solving | Owners Helping Owners 5 05-26-2008 08:09 PM
Anode Rod for heater.. Christi V. Care and Feeding of Molded Fiberglass Trailers 4 04-20-2008 09:25 AM
