Custom Fiberglass Work - Fiberglass RV
Old 01-19-2018, 03:03 PM   #1
Trailer: topper
I'm in need of someone capable of custom fiberglass work for my camper on my 04 Tacoma. I have some ideas of what I want to do to it, but I'm not quite sure if they're plausible. Thanks in advance!
willsittterson is offline   Reply With Quote
Old 01-19-2018, 04:02 PM   #2
Wallo's Avatar
Utah
Have you looked under "boat repair" shops in your area? They may repair many fiberglass boats. If they can't do what you want, maybe they know someone who can. Good luck
Alice
Wallo is offline   Reply With Quote
Old 01-19-2018, 04:48 PM   #3
fiberglass work
guys that like corvettes but I bet it will cost you!!
good luck
bob
Old 01-19-2018, 07:17 PM   #4
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Polyester resin and glas are easy to work with and hsve been around a long time. Stick an ad on craigslist, maybe in help wanted section of your local paper, get references of course but there are lots of people who could help you.
With a little practice you could probably do it yourself.
I didnt know anything about the sruff till I bought some and started playing with it. Today with youtube its even easier!
Fred
FRED SMAILES is offline   Reply With Quote
Old 01-19-2018, 07:33 PM   #5
expert
fred I admire you work you have become an expert
bob
Old 01-20-2018, 11:45 AM   #6
Wallo's Avatar
Utah
Boat repair?
Alice
Old 01-21-2018, 09:01 PM   #7
repair
I knocked a hole in my fiberglass boat got the stuff fixed it myself.
just be patient read up
bob
Old 01-26-2018, 10:34 AM   #8
Trailer: compact hunter II / restoration
Santa Cruz CA
ok, I've worked with FG a long time mostly surfboards from start to finish. here are some quick tips that I used when doing a complete overhaul of my CH. I raised the trailer because of the torsion axle and custom frame that allowed me to cut the top (hump) of the wheel wells out. I also cut two doors in one on each side in the front. this gave me material to use as replacements pieces cut to size for all the holes (old furnace, vents, etc) that I covered. I used the flat pieces from the side and glassed them on top of the wheel wells. working with FG is easy and I might suggest taking some scrap, mix resin/hardener with FG strand (take a piece and cut into tiny shreds) and experiment. less hardener will allow you to play with it a bit. I neat trick is to use MYLAR as in balloons, as backing, resin and glass don't stick to it. especially handy around corners. just tape it on from the outside and work from the inside. sand outside and fill minor blemishes etc w bondo
xmansurfer is offline   Reply With Quote
Old 01-26-2018, 10:45 AM   #9
Santa Cruz CA
it took a few layers to get the thickness needed, but what I did was cut the piece to size, tape it in from the outside and just set a few strips on the inside to hold it in place. once set remove the tape and paste/tape mylar on outside seams...then from inside fill and cloth at least two inches beyond the cut ...don't try and put too much on .....its better to do one layer at a time allowing hardening time.
Old 01-26-2018, 10:49 AM   #10
Santa Cruz CA
see comments below
OH | 2007 Custom Homebuilt 22' Fiberglass For Sale OhTom For Sale: Molded Fiberglass Travel Trailers 5 08-25-2017 06:36 PM
Relic Trailers - Custom fiberglass AWSOME Pam Garlow General Chat 35 08-24-2017 04:45 PM
Fiberglass Work Questions Tom Porter Problem Solving | Owners Helping Owners 6 08-02-2011 03:24 PM
2010 Custom Fiberglass teardrop"Real Kool" Dave Baston Referrals: Molded Fiberglass Trailers 1 06-07-2010 05:14 PM
