cutting fiberglass ? - Page 2 - Fiberglass RV
Old 06-18-2013, 09:14 PM   #15
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I use a 3/4" blade in a dremel oscillating tool.
Old 06-19-2013, 05:57 AM   #16
Abrasive disc in the die grinder is what I used. I've used it to widen the rear window opening when I installed a Scamp window in our Uhaul, and to cut an opening for a new power converter, a storage opening, and increase the opening size where the ice box was to replace it with a dorm fridge. It's a thin disc, worked good, but made a lot of dust. For the corners of the openings I used a toothed hole saw to get a round corner.
mary and bob is online now   Reply With Quote
Old 06-19-2013, 08:52 PM   #17
Brian B-P's Avatar
Thanks Bob
Old 06-19-2013, 10:32 PM   #18
chuyler1's Avatar
New Hampshire
ALWAYS ALWAYS ALWAYS
Wear a respirator when working with fiberglass. You do not want to inhale those dust particles!
chuyler1 is offline   Reply With Quote
Old 06-20-2013, 08:15 AM   #19
Trailer: U-Haul CT-13 1985
Quebec
I installed an air conditionned and did the holes with a small jig saw with a metal blade. Worked great.
Also did exterior holes the same way...
[ATTACH]60737[/ATTACH.
fcharlan is offline   Reply With Quote
Cutting the fiberglass for an AC Kevin A Problem Solving | Owners Helping Owners 11 07-28-2014 01:24 PM
Cutting the budget... Casita Greg Jokes, Stories & Tall Tales 1 02-22-2011 08:24 AM
Done Cutting Up Deer Cyndi B. General Chat 6 12-26-2010 09:44 AM
Cutting Fiberglass Booker B. Problem Solving | Owners Helping Owners 24 05-26-2008 03:40 PM
Cutting Board Legacy Posts Modifications, Alterations and Updates 11 10-03-2002 12:11 PM
