cutting fiberglass ? - Fiberglass RV
Old 06-18-2013, 11:28 AM   #1
starfighter's Avatar
Trailer: Lil Snoozy
I'm adding an access door to vent an a/c unit in our Hunter 1.
I'm familiar with tools and have done extensive woodworking, but not fiberglass. I was planning to use a drill start, then a fine tooth power jig saw to finish the round opening. Anything better /
Thanx for any.
Allan
starfighter is offline   Reply With Quote
Old 06-18-2013, 11:41 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I just put bigger access doors inside under my back bench using a jig saw with a metal blade. Works GREAT. I used some panel trim to finish it off.
Name:	May 12 2013 016.jpg
Old 06-18-2013, 11:55 AM   #3
Trailer: Lil Snoozy
thanx Kevin.....I feel better about starting the project now.
Allan
Old 06-18-2013, 12:22 PM   #4
Roy in TO's Avatar
The oscillating multi tools work good too! I've used the 1/2 round blade. No drill start required, just a steady hand.
Oscillating Multifunction Power Tool w/ Variable Speed
Old 06-18-2013, 12:40 PM   #5
The very best too I've ever found for cutting fiberglass is Dremel's zip tool attachment. Smooth and easy to control. No chip out.
I couldn't remember the exact name. Here it is.
This with the dremel motor makes almost perfect cut.
Old 06-18-2013, 02:37 PM   #6
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Down cutting or down clearing (same thing) saber saw blade (in the range of 12 to 20 teeth per inch does a good job from the face side which is of course also the gelcoat side.
jack
Old 06-18-2013, 02:46 PM   #7
Trailer:
A fine-tooth metal blade in a jigsaw does OK for small cuts but it will get wrecked fairly quickly and will always be a bit grabby. The hot-knife-through-butter tool is a RIFF jigsaw blade like the well-work example below. Its grit-coated edge cuts forever and is very smooth and steerable. They are a bit of a speciality item but are useful for cutting any very hard material.
Old 06-18-2013, 03:18 PM   #8
papa-t's Avatar
Glade Valley, North Carolina
Nice looking job there Kevin
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 06-18-2013, 03:52 PM   #9
Raz
Raz's Avatar
Vermont
If you drill a hole for a jig saw blade, drill it in the waste area as twist drill bits tend to chip out gelcoat. Raz
Old 06-18-2013, 03:58 PM   #10
Trailer: Lil Snoozy
Got 'er done !!!
I did just use my jig saw W/ a many toothed blade after making a start hole. Came out pretty slick.
I put a portable a/c unit in a closet and vented out through a small (5") round access port. When A/C is needed, I just open the port and the closet door, and crank it up...
When not in use, it is not obnoxious.
Thanx for all the help........
Allan
Old 06-18-2013, 04:00 PM   #11
Trailer: 2014 Escape 21
Virginia
I use a multi-tool with a half moon blade. Hold your shop vac near the blade while cutting and it collects most of the fiberglass dust.
Eddie
Old 06-18-2013, 07:36 PM   #12
I use an air powered die grinder with a thin 2" cutting wheel.
mary and bob is online now   Reply With Quote
Old 06-18-2013, 07:46 PM   #13
Brian B-P's Avatar
An abrasive cutting wheel (like a rotary version of Andrew's blade above), or a toothed saw blade?
Old 06-18-2013, 07:48 PM   #14
Brian B-P's Avatar
Has anyone tried an abrasive blade in an oscillating tool?
Cutting the fiberglass for an AC Kevin A Problem Solving | Owners Helping Owners 11 07-28-2014 01:24 PM
Cutting the budget... Casita Greg Jokes, Stories & Tall Tales 1 02-22-2011 08:24 AM
Done Cutting Up Deer Cyndi B. General Chat 6 12-26-2010 09:44 AM
Cutting Fiberglass Booker B. Problem Solving | Owners Helping Owners 24 05-26-2008 03:40 PM
Cutting Board Legacy Posts Modifications, Alterations and Updates 11 10-03-2002 12:11 PM
