Cutting Fiberglass? - Fiberglass RV
Old 09-03-2015, 08:17 AM   #1
Trailer: Uhaul
Cutting Fiberglass?
What is the best type of saw/tool for cutting fiberglass?
Today, I will begin the process of adding an air conditioner to the right front bench cubby of my 86 Uhaul CT
Uhaul Mike is offline   Reply With Quote
Old 09-03-2015, 08:37 AM   #2
David Tilston's Avatar
Many people have use a multi tool, with success. This is what I use.
Old 09-03-2015, 08:37 AM   #3
Trailer: 1993 Bigfoot 17 ftCB / 2011 Toyota Sienna
Tool for cutting fiberglass!
Mike;
I've used an electric jig saw with fine blades (24TPI or 32TPI) but I always use masking tape over the lines to be cut.
Tape your lines and remark them on top of the tape. Always cut from the 'good' side and keep the blade frame tight to the surface and work slowly to minimize splintering.
The tape minimizes marks and splintering. Run a coarse file to clean the cuts after removing the tape and vacuum up the powders and splinters.
Good luck.
Mike .....>
Michael Pupeza is offline   Reply With Quote
Old 09-03-2015, 09:11 AM   #4
Keaner's Avatar
Trailer: 1973 13' Boler
The above advice of a jigsaw with metal cutting blades (32TPI) is good, works like a charm for me. In the places my jigsaw won't go I use a cutting wheel on my dremel.
Keaner is offline   Reply With Quote
Old 09-03-2015, 09:56 AM   #5
Trailer: 2008 Casita 17 SD
I have a Fein Tool oscillating cutter and a Roto-Zip circular cutting tool. While both are very good at cutting fiberglass, I would opt for the Roto-Zip if you have to make curved cuts with a radius edge, to get a more precise and smooth curved edge. For straight cuts, the oscillating blade cutters are great.
Also, wherever possible, you're better off to make rounded (radius) cuts to relieve stress on the fiberglass. Sharp corners invite stress cracking, especially where the fiberglass will be carrying a load, (such as an A/C unit.)
Old 09-03-2015, 10:32 AM   #6
I cut a hole for a propane detector. I used a dremel with a roto-zip attachment. I got the cleanest, smoothest cut you could hope for. No chipping of the gelcoat, just a very smooth cut. It was the easiest cutting tool to control also. I've used lots of cutting tools to cut lots of materials, nothing has come close to the dremel roto-zip.
Byron Kinnaman is online now   Reply With Quote
Old 09-03-2015, 10:34 AM   #7
I have used masking tape and a jigsaw with success on a number of fiberglass cutouts as well. Simple use a drill to drill out any corners to be cutout first.
Old 09-03-2015, 10:46 AM   #8
I use a thin abrasive cutting wheel in a die grinder for most small jobs. I use a shop vac to suck up the dust as I go. For big jobs I use a diamond tile cutting wheel in my 4-1/2" hand grinder. Need round corners use a hole saw in the corners. The more tools you have then the more you can turn a simple project to a full blown exercise of tool invasion.
Old 09-03-2015, 12:49 PM   #9
Trailer:
The nicest tool to use is a jigsaw with a RIFF blade in it.
This may be sold as a tile cutting blade and has a grit-coated cutting edge.
Regular fine jigsaw blades won't last long cutting fiberglass but are great for the occasional small cut.
Old 09-03-2015, 01:37 PM   #10
IllAnnoy
I like the Roto-Zip option.
Old 09-03-2015, 05:23 PM   #11
colinn's Avatar
Trailer: Trillium 13 ft
multimax by Dremel Multi-Max™
Works great for me. I use the wood/metal blade and they last a really long time.
colinn is offline   Reply With Quote
Old 09-03-2015, 05:31 PM   #12
This is the dremel attachment I was talking about. Smooth cutting and no chipped gelcoat.
LINK
Old 09-03-2015, 07:38 PM   #13
CampyTime's Avatar
Trailer: Scamp 13' Standard
I used the dremel as you did Byron with the cutting tool. And a shop vac. Worked well for cutting new door for below main closet in my 13er.
Old 09-04-2015, 05:03 AM   #14
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I use a carbide jigsaw blade. No teeth, just a coarse coating of carbide grit. It sort of like filing the fiberglass. No ragged edges or tearing.
Carbide Grit Jig Saw Blades, ToolCenter.com
My second favorite (described earlier)is a thin cut-off disk on a rotary grinder.
Quando omni flunkus, moritati
Fiberglass Cutting and Cleanest Tool to Use spacey_tracey Problem Solving | Owners Helping Owners 19 08-02-2014 03:11 PM
Cutting the fiberglass for an AC Kevin A Problem Solving | Owners Helping Owners 11 07-28-2014 01:24 PM
cutting fiberglass ? starfighter Modifications, Alterations and Updates 18 06-20-2013 08:15 AM
Cutting Fiberglass Booker B. Problem Solving | Owners Helping Owners 24 05-26-2008 03:40 PM
