Danfoss compressor fridge - Fiberglass RV
Old 02-28-2016, 03:11 PM   #1
Trailer: Boler 1974 13 ft
Hi all,
I am looking for those who have used a portable fridge/freezer in their TT. I am planning to full-time using a 12v/110 fridge running on batteries charged with solar panels. For those who have used these portable fridge/freezer, please share your experience with brand, size, quality of unit, life of unit, what can you store in it in the real world, would you buy it again or not and why.....thanks for helping me learn from your mistakes.
Lisa in FL is offline   Reply With Quote
Old 02-28-2016, 05:46 PM   #2
I cant talk about the Danfoss, but I have a Norcold with a swing compressor that draws about 3.7 amps. and runs about 30 % of the time.
I have added a small commuter type fan to move air over the cooling fins to hopefully make the thing more efficient installed in the camper.
I have installed a DC power meter and currently I am currently defrosting the fridge and when I reload it after it cools I will test the thing for 24 hours.
Old 02-28-2016, 08:06 PM   #3
Thanks, I look forward to your results
Old 02-28-2016, 09:12 PM   #4
Jack Walter's Avatar
Trailer: Eriba Triton now - ex U-Haul, Boler owner
I use a 35 quart Engel and it is fantastic. My only regret is that I didn't get the 45 quart size. Get the transit bag to help insulate the fridge/freezer/ The ARB units are great too. There are at least 25 Engel and ARB fridges in my local Land Rover club and everyone has nothing bad to say about them. They only draw about 1.5 amps and will freeze ice cream at any setting over 3 on the dial. A good solar panel can easily stay ahead of the power draw on a 12v battery.
Lots of information on these on the Expedition Portal in the Support Equipment forum
Expedition Portal Forum
Jack Walter is offline   Reply With Quote
Old 02-28-2016, 09:14 PM   #5
Mike Magee's Avatar
Trailer: Li'l Hauley
MCDenny has one, and a solar panel to charge his battery. You might send him a PM.
How to prepare Tofu
Step 2: grill some meat
Old 02-28-2016, 11:37 PM   #6
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I had a Nova Kool NovaKool DC Refrigerator - Model 4500 in our 13' Scamp to replace the 3 way refrigerator that became unreliable. I did add insulation around the refrigerator once installed as recommended to reduce run times. . I used a single 100 watt solar panel to keep our group 27 battery fully charged each day during our travels to California, Oregon, Washington, Northern Idaho, Colorado, Michigan and all places along the way, and it never failed nor drained the battery below 50%. I would recommend it. I now have a Truckfridge of the same size in our Lil Snoozy, but without additional insulation as there wasn't room for any. This set up requires two 100 watt solar panels to keep up with the power demands, as it appears that this unit runs more often and longer to keep things cold.
Dave & Paula
Old 02-29-2016, 03:18 AM   #7
Thanks everyone, this input is all very helpful.
Old 02-29-2016, 03:29 AM   #8
Could you tell me how to find him on the forum please? I have only contacted people from threads, thanks.
Old 02-29-2016, 04:25 AM   #9
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
You could look him up in the member directory (community, near the top of each page, then member list), click on his name (scroll through the list or search), then on contact information then click on send him an email....
Email addresses are hidden until you/he elect to share.
Quando omni flunkus, moritati
Old 02-29-2016, 07:50 AM   #10
Thanks Steve, I will try that. Hope it works on my phone.
Old 02-29-2016, 07:52 AM   #11
Does anyone have experience with the brand called Indel B? The Engel is too expensive for my resources.
Old 02-29-2016, 09:57 AM   #12
David B.'s Avatar
Trailer: Lil Snoozy
You can find Denny Wolfe at Wanderingourway.wordpress.com
Dave & Paula
Old 02-29-2016, 10:52 AM   #13
Timber Wolf's Avatar
North Florida
I have the biggest Truckfridge (TF130) in 12V and like it a LOT. Although there is a dual voltage version (12&120V) I went with the cheaper 12V only as my Scamp has a (brand new) 120 to 12V converter so I saw no need for the fridge to be 120V capable.
I can't remember the specs right now but I was a little surprised at how much it runs and how much juice it draws. To be fair, we have the door open a lot, it is a larger unit than we had to have, and I run it colder than required. But I wanted the larger unit for longer trips, plan on solar to recharge the batts, and in State Parks we have 120V anyway. I should mention I added as much foam around the sides, back, and top that I could in the space provided without blocking air flow over the coil. The running noise is noticeable but not bad and does not bother us at all.
It is so nice to be able to plug in at the house a day before a trip and having a VERY cold fridge to start out. Then it runs fine under way, and again at the site whether plugged to shore power or not. This seamless transition from house to road to camp and back is a BIG plus to me, not having to mess with a propane fridge.
My goal when I installed this fridge was three days without charging and without dropping below 50% capacity on my dual 6V batteries. I have not been camping enough, or tested it scientifically enough to say with certainly if I have met that goal. My feeling is it is achievable but we are in and out of the fridge too much and I am running it too cold. I have other loads such as a CPAP machine that have to be met also.
I have not installed my solar system yet, but others have done so successfully so I feel in the end I will be fine with the Truckfridge and solar for all our 12V needs.
I do think that most people would be better served with one of the smaller units, or even one of the chest types. The front door versions "dump" a BUNCH of cold air every time you open the door causing the thing to have to run to make up that lost coldness. Also, one of the portable chest types could be put in the tow and ran while you are out and about from camp.
Timber Wolf is online now   Reply With Quote
Old 02-29-2016, 11:08 AM   #14
I have two-way ( 120V / propane ) 5 cu. ft. fridge.
I plug it in to the mains at home a couple days before a trip to pre-cool it and load with food ( beer usually ).
Depending on the length of the trip, I will either just turn it off for the duration, or switch to propane.
It's not a problem as you seem to indicate Tim.
fridge
Compressor style AC/DC fridge bcarey172 Modifications, Alterations and Updates 13 04-17-2015 06:21 AM
2 way compressor fridge vs 3 way propane aimeelightsey General Chat 9 05-20-2011 05:56 PM
12-volt marine fridges with the Danfoss compressor Loren G. Hedahl General Chat 13 04-05-2008 05:27 PM
new compressor fridge Joe MacDonald General Chat 2 02-15-2006 01:38 PM
Compressor Refrigerator Pete Dumbleton Problem Solving | Owners Helping Owners 4 11-18-2005 09:17 AM
