Do I have a converter in my Scamp? - Fiberglass RV
Old 05-06-2014, 09:48 PM   #1
Trailer: 2000 17' Bigfoot CB
Nebraska
I bought a 13' 1990 Scamp recently and was doing a test run to power it off the battery. When it didn't work, I followed the leads and found they were cut off underneath the front seat.
Underneath the sink there is a circuit breaker, which the main AC cord goes into and gets distributed to a few other AC outlets. I don't see any other electrical boxes near by.
So, do you think a previous owner took out the converter? Or is it located somewhere else?
chud13 is offline   Reply With Quote
Old 05-06-2014, 09:54 PM   #2
Did you look under the rear benches? thats where mine is on my 92.
Old 05-06-2014, 10:06 PM   #3
Nebraska
Nope, nuthin under the benches.
Old 05-07-2014, 05:15 AM   #4
Tim Wood's Avatar
Trailer: Class B for now
NY
Chad, You may not have one, I had an older Scamp with out a converter. Easy fix. Take a maintenance type battery charger, plug it into a 110 receptacle , and take the leads and run them to the battery. Now when you are hooked up to shore power, you will be charging your battery and not overcharging like some older converters.What I did is run a new 110 receptacle under the front bench I think, then ran the leads to the battery.
Old 05-07-2014, 06:46 AM   #5
Nebraska
Ok the battery charger hook up makes sense. My next question would be if there is some sort of distribution center for the 12 volt. The 12v leads we're cut very near the battery. So where are all the wires for all the 12 volt lights?
Old 05-07-2014, 07:38 AM   #6
Procreative Dynamics make a nice 12 circuit DC Distribution/Fuse panel that mounts through the wall with fuse LEDs, about $50
Or you can check at your local Boat Supply shop for a 12VDC distribution panel, might be a little more expensive, but instant gratification is yours.
Old 05-07-2014, 08:59 AM   #7
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Sounds similar to what I just dealt with with my '85
Progressive dynamics 4045 DC wiring
How i dealt with it.
summer scamp is offline   Reply With Quote
Old 05-07-2014, 09:23 AM   #8
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
My '98 16' Scamp did not come with a converter. All the 12v wiring ran up and hooked to the battery. That was it-nice and clean. I have since added a small converter(shouldn't have-it was old and not worth the trouble). I bought a battery tender jr., and I plug the battery into it whenever I camp with power(my added converter does not have a charger function).
Dennis
Dennis Clinton is offline   Reply With Quote
Old 05-07-2014, 09:39 AM   #9
Nebraska
If the battery was still hooked up to all the 12V accessories, I probably could have lived with that for a while, but since I will have to rewire all the DC wiring anyway, I ordered a Progressive Dynamics AC/DC distribution center thingee.
Old 05-07-2014, 10:04 AM   #10
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Which model did you go with?
Old 05-07-2014, 10:18 AM   #12
Name: Kevin & Lisa
Trailer: Scamp16
Ohio
Well I hope so cause it's what I just installed
Feel free to PM me to relieve any installation heartache when u get there.
Old 05-07-2014, 10:27 AM   #13
Nebraska
Ha! Sounds good!
Old 05-07-2014, 10:55 AM   #14
I've installed 7 of them without problems, but be sure you connect the 120VAC lead to the converter section with it's own circuit breaker.
I have a question Why do I need a converter? neauone Electrical | Charging, Systems, Solar and Generators 34 10-01-2013 06:45 AM
Why does the converter/refrigerator have a plug? pindraak Problem Solving | Owners Helping Owners 38 05-02-2012 09:48 AM
Scamp Power Converter Bill A Problem Solving | Owners Helping Owners 5 06-17-2007 01:44 PM
Confused! Converter...do I even have one?? Tirah Problem Solving | Owners Helping Owners 1 07-22-2006 03:29 PM
Scamp Electric Converter Legacy Posts Problem Solving | Owners Helping Owners 3 05-19-2003 01:30 PM
