Do you tow with a Honda Odyssey? - Fiberglass RV
Old 11-12-2005, 09:29 PM   #1
Trailer: Fiber Stream
The "Back" bucket seats; a.k.a. the Second Row Seats are removeable...
Old 11-12-2005, 09:31 PM   #2
Talking
First, fold the back flat...
Old 11-12-2005, 09:33 PM   #3
Talking
Then, reach under the front outboard corner, pull the release, and rotate the whole seat forward...
Old 11-12-2005, 09:35 PM   #4
Talking
Now that the seat is released from the floor anchors, it can be removed from the vehicle...
Old 11-12-2005, 09:40 PM   #5
Talking
Here's where I studied the situation to make my mod. I wanted to re-create the floor anchors in a portable platform that I could use at my campsite. For this I thought and thought about what would be the simplest design to accomplish my goal. I came up with a minimalist frame...
Old 11-12-2005, 10:00 PM   #6
Talking
When I was camping at Cibbets Flats last month, Gina pointed out some abandoned lumber, that someone wanted to burn, but campfires were restricted that weekend. I found 4 identical pieces, 2" x 2 3/4" x 23" long.
Then I studied the floor anchors in the van. They are made out of rods with different diameters. This is so you do not install them in the wrong positions; preserving proper seat belt function. I discovered:
The rear anchor rods on both seats are the same. 3/8" diameter.
The forward anchor rods on the Passenger side seat are 1/2" diameter.
The forward anchor rods on the Driver's side seat are 1/4" diameter.
The forward-to-rear rod spacing on the Passenger side seat is 11 3/8" centerline-to-centerline.
The forward-to-rear rod spacing on the Driver's side seat is 11 5/8" centerline-to-centerline.
I went to Home Depot and bought galvanized steel rods:
2 each at 3/8" diameter
1 each at 1/2" diameter
1 each at 1/4" diameter
They are sold in 36" lengths. I cut them down to 23".
Then I drilled appropriate sized holes, 1 inch deep, at appropriate spacing that was different for each pair of wood blocks.
This got me 4 blocks and 4 rods:
Old 11-12-2005, 10:01 PM   #7
Talking
Assemble the rods into the holes in the wood...
Old 11-12-2005, 10:03 PM   #8
Talking
...and place the assembled frames on your patio mat next to your trailer...
Old 11-12-2005, 10:07 PM   #9
Talking
Now bring the seat you removed from the Odyssey Minivan, and place the front facing frame groove over the forward rod; in the same position you removed it from the Van...
Old 11-12-2005, 10:10 PM   #10
Talking
In the same manner that the seats are installed inside the Van, push the rear latches down over the rear rods.
Old 11-12-2005, 10:12 PM   #11
Talking
...and bring your seat-back (but no tray table) into an upright position, rotating the armrests down to their useable position.
Old 11-12-2005, 10:15 PM   #12
Talking
Repeat the process for the other seat, and viola! A pair of comfortable chairs at your campsite. ...complete with built-in cupholders!
Old 11-12-2005, 10:18 PM   #13
Talking
They even recline! The seat's forward/back adjustment is fully functional; ensuring that you won't tip over as you recline back!
Old 11-12-2005, 10:32 PM   #14
Gina D.'s Avatar
West Coast USA
Those are great. I wish that would work for Element seats.
Very clever!
Honda Odyssey Van Tom B Towing, Hitching, Axles and Running Gear 12 04-20-2009 09:05 AM
SOLD - 2003 Casita Spirit Deluxe and 2005 Honda Odyssey Nancy Wright Classified Archives 10 03-15-2009 02:57 PM
Towing with Odyssey Pete Dumbleton General Chat 8 04-01-2008 11:01 PM
99 Honda Odyssey as a tow vehicle? Cam A Problem Solving | Owners Helping Owners 6 03-01-2007 03:36 PM
Odyssey owners... HELP!!!! Roger H Problem Solving | Owners Helping Owners 25 03-12-2006 06:29 PM
