Dog proofing the screen door - Fiberglass RV
Old 01-30-2019, 11:27 AM   #1
My understanding is that the Casitas come with a full length screen door. Since I camp with my overactive Brittany, I am wondering how hard it would be to remove the screen door or to cover it with something from the inside that would protect paws from going through the bottom half of it. Has anybody ever dealt with this issue? Since I haven't actually seen the unit I have no idea what to expect. All I know is that dogs being dogs, the paws are going to go through the bottom half of that thing in very short order.
Art
ae6black is offline   Reply With Quote
Old 01-30-2019, 01:13 PM   #2
Trailer: Lite House
Installing something like this down at dog level would help remind that dog that there is a door there.
https://www.amazon.com/dp/B00OJM78Z0...v_ov_lig_dp_it
But if they are still going to jump on the door and such, a solid panel might be a better idea.
Steve Carlson is offline   Reply With Quote
Old 01-30-2019, 02:07 PM   #3
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
Easy fix
They make mesh dog screens or get some hardware cloth at local hardware store or big box store
I’m sure you can find one on line as well
alan H is online now   Reply With Quote
Old 01-31-2019, 11:56 AM   #4
Trailer: 2017 Escape 5.0 TA
Connecticut
Check out Amazon: Screen door protector.
Lots of options and price ranges
Cliff Hotchkiss is offline   Reply With Quote
Old 01-31-2019, 12:33 PM   #5
I cut a thin piece of plexiglass I got at Lowes to fit inside the lower half of the screen door. If you will notice there is a groove on the inside of the screen door. Cut the plexiglass wide enough to fit inside this groove. Then cut it high enough to fit in the bottom but just short of the top. In this way one can bend the plexiglass to fit inside the two sides of the groove, then slide it down into the bottom groove. Having these 3 sides in the screen door hold it in nicely. Since the top of the plexiglass won't be in a groove, I just used a piece of black tape to hold the top flush with the metal of the door. It has worked for four years with no issues. We have two small dogs. You can cut the plexiglass with a utility knife and a straight edge. Once you have scored the plexiglass it will snap off or just ask a Rep. from Lowes (or where ever you get it ) to cut it for you.
m1mbeverly is offline   Reply With Quote
Old 01-31-2019, 12:51 PM   #6
Thanks, that was something that I was hoping for. Since I don't have the trailer yet, I am just spending the winter thinking through my issues before I have them.
Art
Old 01-31-2019, 12:55 PM   #7
Your welcome, it was the first a many mods I have done since got my Casita!
Old 01-31-2019, 01:42 PM   #8
NW Cat Owner's Avatar
Trailer: Escape 21' 2nd Gen, picked up on Black Friday 2016
I'm thinking you might want to add some sort of decal or some such on there so the dog knows it's a solid barrier since the plexiglass will be clear.
Yep, one more thing to think about over the winter!
Laura and Dirk, and Spike, Sam & Jasper (the cats)
www.UnderKittySupervision.com
NW Cat Owner is offline   Reply With Quote
Old 02-01-2019, 09:16 AM   #9
Trailer: BigFoot
We don't have a dog. My problem is dogs and little kids pushing on the screen door to get in. Came close to happening at a rest stop with the door open. The guy caught his kid in the nick of time.
The problem is that many screen savers are too thick to put on the outside of the screen door because it won't be able to lock into the the outside door. So plan accordingly.
Rzrbrn is offline   Reply With Quote
Old 02-09-2019, 02:05 PM   #10
Dog Proofing Door Bottom.
Our wonderful beagle, Sierra, took out the screen bottom portion of our Casita door. My fix was to replace it with thin sheet metal ( press plate ). I cut it oversize and notched the corners then bent and vee'd the sides so that it could be pressed into the groove. Sierra learned that the metal was a little noisy and has left it alone since.
David Marowski is offline   Reply With Quote
Old 02-09-2019, 02:59 PM   #11
Trailer: looking for a projekt
Sörmland
Homemade removable polycarbonatedoor and Scotch fastener
helgestahill is offline   Reply With Quote
Old 02-09-2019, 04:28 PM   #12
I wonder if you could put that on a hinge.. the problem I have is that the dog barrier is also a people barrier, and when it is in place its hard to impossible for me to get in and out. I need something I can swing out of the way easily.
Old 02-09-2019, 05:40 PM   #13
Kip in Ga.'s Avatar
Trailer: 2003 Casita 17' SD Deluxe, Towed by '09 Honda Ridgeline.
Mike' suggestion on post 5 should work fine. Our 03 Casita screen door grooves are on the outside of the door, so the screen would have still been available to the pup's nails. So I attached it to the inside with rivets.
Our pup is an escape artist, so I built and installed a hinged spring loaded gate between the bathroom and fridge. So she can't sneak by as we open the door.
k
Kip in Ga. is offline   Reply With Quote
Old 02-09-2019, 07:00 PM   #14
I installed hardware cloth over that area and problem solved. It is durable and it has been there now for a couple of years, problem solved.
Perry Camper is offline   Reply With Quote
Dog & Screen door jgilliam1955 General Chat 9 10-06-2018 12:31 AM
wind proofing trailer ninklink Problem Solving | Owners Helping Owners 14 09-11-2017 04:28 PM
Theft-proofing battery?? War Eagle Problem Solving | Owners Helping Owners 18 04-07-2014 03:30 AM
Rust Proofing Fibreglass RV Metal Frame Randy J. Problem Solving | Owners Helping Owners 6 11-05-2013 10:15 PM
Mouse Proofing Sonny Care and Feeding of Molded Fiberglass Trailers 21 06-25-2007 10:06 PM
