Door Accessory Mount Panel - Fiberglass RV
Old 09-07-2013, 06:49 PM   #1
Trailer: Escape 19
Delaware
A minor mod to make mounting things on the door easier using alum for weight savings. If you want specifics and materials used etc let me know. I know a lot here eschew drilling holes however, I only added 4 more to the two existing ones. This mod allows you to change things as you want and even change the panels when you want to rearrange with out drilling any more holes. No special tools needed with the exception of a pop rivet gun. However, some special tools make it go faster enjoy. This is also Posted on Escape Forum.
Cypherian
Mounted
Full Door Mounted
Burnished (By Hand)
Bag Holder Mounted
Screen Door Clearance 1/2"
Door Closed Screen Door Open
I have not decided yet what to put on the empty space yet LOL I am sure it will come to me what to put there.
Cypherian
Cypherian is offline   Reply With Quote
Old 09-07-2013, 07:05 PM   #2
Roy in TO's Avatar
Pics don't show here. Wonder if escape forum is blocking download for nonmembers.
Old 09-07-2013, 07:30 PM   #3
Trailer: Escape 19
Delaware
Weird they are showing when I look at the post. let me try uploading them again it failed and I just copied the post from there to here.
Cypherian
Old 09-07-2013, 07:56 PM   #4
Whatever you did, they're showing now. Looking good
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
What to replace a fridge door panel with? Carol H Modifications, Alterations and Updates 20 04-30-2011 05:53 AM
need new door mount bolts thenoob Problem Solving | Owners Helping Owners 3 02-07-2011 03:11 PM
Flat Panel TV Mount Install efawcett Modifications, Alterations and Updates 10 07-23-2009 04:59 PM
Panel Mount Voltage Meter efawcett Modifications, Alterations and Updates 8 07-19-2009 11:54 PM
