Dream Solar system - Page 3 - Fiberglass RV
Old 10-08-2012, 06:45 AM   #29
honda03842's Avatar
Name: Norm and Ginny
Steve, It's hard to beat a propane based refrigerator. They are expensive but great for boondocking. If you add an electric fridge I'm sure it will be your biggest user of electricity no matter it's efficiency. How efficient is it?
In reality we find we use very little electric power when off the grid between the TV, Sat Dish, LED lighting, Wi-fi hotspot, computer charging and water pump. Certainly the water pump is the biggest instanteneous drain.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-08-2012, 12:16 PM   #30
Trailer: Trillium Outback - 2004
Steve, my setup is almost exactly what you described. I use a novakool fridge, it draws around 2 amps when running, nothing when not. Charging under load is something Iíve monitored. Using a Trimetric Iíve seen an average charge of 2-3 amps go into negative territory when the compressor kicks in. This causes the voltage to drop then climb back up when the fridge turns off. The voltage yo-yo is terrible for charging as you need to keep a constant voltage for long enough to actually charge the battery. So my recommendation is to have a panel/controller combo to negate any common loads (like a fridge not a stereo) while charging, but only if it meets your budget.
MPPT is a winner when the panel voltage is much greater than the battery voltage. With my current setup Iíve never seen a bonus, but I have seen my panel hit itís STC rating which Iím not convinced would happen with a PWM controller. My goal is to go high voltage, if not I might have considered a higher quality PWM controller as they arenít expensive.
Here is a long article which explains panel efficiencies, well worth the read: Photovoltaics Modules 101 from Sunlight Electric
Where weíre going, we donít need a plug-in.
multi-task is offline   Reply With Quote
Old 10-08-2012, 03:02 PM   #31
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
Honda, the 12v fridge I'm talking about is even more expensive than a 3 way. However they are ultra efficient, keep things much colder, don't need leveling, and get cold faster. These aren't dorm fridges tied to an inverter like some people use. I had one in my Trillium and LOVED it. The only problem is the biggest I found is a 2.7 and I want one a bit bigger.
Old 10-08-2012, 03:53 PM   #32
Trailer: 1984 13' UHaul
Louisiana
I just checked the specs on the Novacool fridges. They use 2.5A @ 12V. That is very good and comparable to Engel fridges which (if you ask me) are the top of the line.
I sold my Engel with my last vehicle (wish I hadn't)!
FYI- I replaced the Engel with a Chinese Whynter fridge. The FYI is ALL the Whynter ads say their fridges use 2.75A @ 12V ,which would be great, but they actually use 5.8A @ 12V. Now, when you put together a small solar system, that is a huge draw!
I have brought this to the attention of Whynter LLC. but they have yet to change their ads. I would NOT buy a Whynter fridge if you'll be using it on a small system.
The problem is compounded by the fact that the sellers on Ebay just copy/paste from the Whynter website, perpetuating the flase info.
I would buy the Novacool with it's low amperage use!
I would buy this (if it will fit)-
Engel SB70F DC Only 12V Front-Open Fridge 60 Quart | eBay
I use the chest type like this- I like the chest type because it doesn't lose the cold when you open it.
itlives is offline   Reply With Quote
Old 10-08-2012, 07:01 PM   #33
I would consider the chest type in addition to the regular but not as a stand alone fridge. I believe this is the Norcold/Thetford model that I had. It uses 2.5 to 3.1 amps.
Model Height Width Depth DC-0051 20-1/2": 520.7 mm 18-1/2": 469.9 mm 21": 533.4 mm Model Interior Volume Net Weight Shipping Weight DC-0051 2.7 cu.ft.: .82 cu.m.
49 lbs.: 22 kg. 58 lbs.: 26 kg.
Door Panel Dimensions
Model Height Width Thickness DC-0051 16-1/2": 419.1 mm 17-1/8": 434.9 mm 3/16": 4.8 mm
Power Source
Model Amps 12-24V/DC DC-0051 2.5-3.1
Old 10-08-2012, 10:27 PM   #34
I can vouch for nova kool, it runs at or better than spec and it`s from 2004. Mine is quite small, I think around 2.1 cubic feet. At 12v it`s stamped to run at 2.2 amps but runs closer to 2 which was a nice surprise.
Old 10-09-2012, 04:08 AM   #35
honda03842's Avatar
What is the duty cycle of the 2.5 amp current draw? What percentage of the time does the cooling cycle run?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-09-2012, 06:25 AM   #36
Norm,
I can't say, would have to research that as it would depend on outside temps, etc. I will say that I was getting 2 to 3 days off grid with a single old 12v battery with no solar, generator, etc. I was in 50-60 degree temps at Ocean Shores Washington rather than in the heat of the desert. Essentially, other than 1 light sometimes, it was the only appliance I had. I'm sure with 2 healthy batteries and an adequete solar system one should be able to go indefinately. I believe Egg campers makes an all electric version, they may be able to supply you with their research.
Old 10-28-2012, 11:44 AM   #37
Trailer: Escape Trailers
Massachusetts
Originally Posted by Steve Hammel View Post
Good Info! I'm such a novice when it comes to solar. I was reading some of the ad info and what appeared to be the better/most expensive panels listed "efficiency rates". Surprisingly these went from 14% up to 19%. To me this was quite shocking as I expected better. The cheaper units didn't even bother to list their efficiency rates. I also hear that there is a huge difference in efficiency between the MPPT and PWM controllers with the MPPT being superior. What is the key thing I should look for in a decent panel? I am going with 2 6v deep cycle batteries (like what Costco or Sams Club sells). I will be installing Led lights inside but I'm also leaning to a 12v high efficiency compressor refigerator. I rarely go more than 3 days w/o being plugged in somewhere for a night.
Where/how do you plan to mount the two batteries on your 5er?
Stretcher is offline   Reply With Quote
Old 10-28-2012, 03:02 PM   #38
I'm going to mount them in the front by the landing gear where the newer Scamp 19's have built that shelf to hold the battery and propane tanks. I will go to one tank. I have the original 20 tanks but I also have 30's and 40's if I need more capacity.
solar
Bigfoot Solar System Tim D. Modifications, Alterations and Updates 16 04-09-2018 11:07 AM
My New Solar System Sharon G Modifications, Alterations and Updates 28 05-20-2013 05:12 PM
Burro enters solar system rabbit Modifications, Alterations and Updates 4 07-04-2011 05:49 AM
can you mix solar system brands? Nancy H Electrical | Charging, Systems, Solar and Generators 2 06-15-2006 07:47 PM
Solar System Advice Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 05-13-2003 10:03 PM
