Old 12-20-2011, 06:20 PM   #1
Thomas G.'s Avatar
Trailer: UHaul CT13 TV: Escape Hybrid
SE Michigan
Drilling hole in UHaul floor - sealing
I need to put a couple of additional holes in the floor of my UHaul to run wires to allow the TV to charge the camper battery. The floor is in excellent shape and I suspect it is because it was originally carefully laminated and the plywood inside has been protected from the elements.
So my question is: How do you reseal the edges of the hole to maintain the integrity of the lamination? Do you drill the hole oversize and insert fiberglass mesh and resin to seal the edge? Or maybe create a little mold and pour pure resin around a tube through the floor? What kind of a drill would cause the least amount of damage to the edges?
Thanks in advance for your thoughts.
Old 12-20-2011, 08:19 PM   #2
Trailer: U-Haul 16 ft Vacationer (VT)
Oak Park, IL
Well, I guess I wasn't nearly as thoughtful as you when I drilled our holes. I needed to run some new ground wires to one side, so I went under the trailer and drilled a new half inch hole with a regular wood bit up need the power converter. It did splinter a little, but it will never be seen inside the cabinets. When the wires were run, I filled the hole with black butyl sealant in a tube, gradually filling it from under the trailer. I'm sure it's not neat to view, but it seals out the water and coats the wood in the floor. I imagine you might also be able to get a rubber grommet that would do something similar. Needless to say, I was in a hurry because we had a trip starting the next day.
Old 12-20-2011, 09:02 PM   #3
Trailer: 2006 Scamp 13'
Sometime back I saw a good idea about holes in trailer floors where the wood was encapsulated. Here's I remember
Drill a hole larger than you need.
Fill the hole with resin.
After resin is cured drill the correct size hole in the center of the resin.
This keeps the wood sealed.
This would also work on Scamp with the resin coated exterior floor.
Old 12-21-2011, 04:58 PM   #4
Thomas G.'s Avatar
SE Michigan
Great idea. I was over analyzing. The resin would bond well to the freshly cut edges, then?
Just call me Tom.
Old 12-22-2011, 05:21 AM   #5
james kent's Avatar
Trailer: Boler 1984
Yes! This is a method often used, in our canoe club, by people that make or use cedarstrip canoes or kayaks to add attachments.
uhaul
Sealing Uhaul Tailights? Patty S. Problem Solving -- Owners Helping Owners 8 07-30-2012 04:35 PM
Sealing the PopRivets Pam Garlow Problem Solving -- Owners Helping Owners 4 09-18-2010 03:25 PM
Drilling the frame Per Walthinsen Problem Solving -- Owners Helping Owners 9 07-31-2008 09:14 PM
Drilling stainless steel sheet metal? Tom Myers Problem Solving -- Owners Helping Owners 8 11-02-2007 08:13 AM
Sealing/Repairing Underside of Floor Jeff G. Problem Solving -- Owners Helping Owners 3 06-28-2006 02:17 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
