Drip cap for Boler door - suggestions on how to install - Fiberglass RV
Old 09-07-2013, 07:01 AM   #1
I bought a replacement drip cap for the door of our 1974 boler from scamp trailers.
It's an aluminium model. It has holes so it can be rivered in place.
I'm unsure how to install it. Do I need some kind of backing tape behind it, or do I just rivet the thing right onto the fiberglass and run a bead of sealant around the top edge?
(ALso I was surprised at how thin the metal is on this thing. We're talking coke can thin. Are the original drip caps that thin?)
PatrickN is offline   Reply With Quote
Old 09-07-2013, 07:05 AM   #2
Yep Patrick, the aluminum is thin. That's okay tho... it only needs to carry the weight of a stream of water. These things have worked well for decades, just as designed.
I'd use butyl and rivets. Then use caulk on the rivet heads. You don't need to run a bead on the top edge if installed properly. But you could. Just be neat and DON'T use silicone!
Old 09-07-2013, 07:12 AM   #3
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
Donna has it right, that's how I put mine on. But I did not have the insulation in yet so could get washer in behind the rivets.
It is probably made from recycled Coke cans. LOL
Rick Mooyman is offline   Reply With Quote
Old 09-07-2013, 07:26 AM   #4
Thanks for the replies. Any suggestions on where to get good quality butyl tape in Canada?
Old 09-07-2013, 11:12 AM   #5
Manitoba
Any glass place such as Speedy Auto Galls or the likes or RV Parts Dept. should carry it.
boler
replacing the drip cap over the door gihuff Care and Feeding of Molded Fiberglass Trailers 7 06-30-2013 11:41 PM
Snap cap/Button cap question Kevin K Problem Solving | Owners Helping Owners 5 06-19-2012 11:50 AM
Suggestions on door seal? 81Honey Problem Solving | Owners Helping Owners 4 06-07-2012 12:06 PM
U-Haul CT-13 Drip cap Mouse Problem Solving | Owners Helping Owners 5 02-13-2012 09:37 AM
Looking for a 29" Drip Cap Sharyl Allender Problem Solving | Owners Helping Owners 6 08-04-2009 11:33 PM
