Duo-Therm Cool Cat Heat Pump - Page 2 - Fiberglass RV
Old 01-14-2013, 09:39 PM   #15
cpaharley2008's Avatar
I had this unit in my T@da, very noisy and the heat pump is a cool heat, in other words it come out about 2-3 degrees warmer than the setting.It was too large for the small T@da which was 16'. It would cool down in about 5 minutes and cycle on and off in the Florida heat. The heat part also only good down to 40 degrees F so it is not a furnace but merely supplemental heat in the 40-70 degree range. You will still need a propane furnace for heat.
I want to also warn that the surge on these units is too high for a 2000 watt generator to operate.
Duo Therm Furnace Settings Chris McVeigh Problem Solving | Owners Helping Owners 22 01-28-2017 03:41 PM
Duo-Therm RV furnace for sale Marv Watson Care and Feeding of Molded Fiberglass Trailers 0 04-20-2009 05:21 PM
Duo-therm parts bill m Problem Solving | Owners Helping Owners 12 04-13-2009 08:48 AM
Duo-Therm Gravity Furnace Jake Jacobson Classified Archives 1 11-10-2008 03:13 PM
Colors & Heat Legacy Posts Electrical | Charging, Systems, Solar and Generators 25 07-11-2003 12:09 PM
