Edge molding - Fiberglass RV
Old 03-13-2015, 06:33 AM   #1
Filbert V.'s Avatar
Trailer: Tote N Tarry
Edge molding
Does anyone know where I can purchase some snap on edge molding for the bottom edges of the fiberglass shell? You know the part around the wheel wells and rest of the body which are sharp and make for some painful scrapes on your skin like when you're washing the tires? I see the Scamp website has some for around the door edge, but not for the body. Thanks!
Filbert V. is offline   Reply With Quote
Old 03-13-2015, 06:47 AM   #2
Edge molding
Did you call them and ask? Since they still use it, they must keep it on hand.
BTW, I believe it is riveted in place.
Old 03-13-2015, 06:49 AM   #3
Filbert, it's Trim-Lok. Plastic & Rubber Trim & Seals | Rubber Molding & Window Trim | Trim-Lok You can even purchase it through JC Whitney.
Locally you might find it at a boating supply house or automotive upholstery place, etc.
Old 03-13-2015, 07:40 AM   #4
Filbert V.'s Avatar
Thanks Donna! Any idea what size I would need. I'm terrible at measurements like 3/8s, 7/16, etc. How thick is my egg shell you think?
Old 03-13-2015, 07:49 AM   #5
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I know the shell on my Trillium is less than 1/8" thick.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 03-13-2015, 07:49 AM   #6
Filbert, I'm sorry I can't answer your questions. Perhaps contact Trim-Lok and ask them how to measure the thickness you need? The Trim-Lok I've used has metal on the inside and it doesn't spread or pinch easily so I'm sure you'll want to get the correct size.
Best of luck!
Old 03-14-2015, 06:56 AM   #7
Trailer: Scamp - The Haunted Mansion
Scamp does have the edging....it's on the parts store page under tapes and trims. Though I like the idea of the Trim-lock edging where you don't have to rivet it in place! That would save tons of time on installing it!
Sohkraites is offline   Reply With Quote
Old 03-14-2015, 07:31 AM   #8
Ian G.'s Avatar
For a very clean look I have seen door edge protector used, looks real good.
Should be available at any automotive parts or accessory store and made is several sizes and widths
Old 03-15-2015, 07:09 PM   #9
Idaho
You guys are the best. I need to replace the metal core plastic trim on my Scamp but was dreading working with it. Now I have options. Thank you, thank you.
CathyB
CBinID is offline   Reply With Quote
Old 03-15-2015, 07:16 PM   #10
perfectfit.com has the trim for various thicknesses but you have to buy 100 feet. I bought some from JC Whitney in a shorter length
Old 03-15-2015, 10:15 PM   #11
Borrego Dave's Avatar
Another option for you, once you find out the size you need, you may want to try finding it on Ebay as sellers tend to list shorter lengths than a 100'.
What can I use to trim the edge of stove cutout??? Vickie B. Problem Solving | Owners Helping Owners 8 05-27-2011 01:07 PM
Replacing Scamp aluminum drip edge Evergreen Modifications, Alterations and Updates 8 02-17-2011 09:57 PM
Trim for table edge Steve in TX Modifications, Alterations and Updates 3 12-22-2010 09:13 AM
Edge Cover - Help Needed Judith Kennedy Care and Feeding of Molded Fiberglass Trailers 15 10-21-2009 02:39 PM
edge protector strips ronsmith100 Care and Feeding of Molded Fiberglass Trailers 5 04-02-2009 01:35 PM
