Old 05-02-2011, 10:13 AM   #1
cpaharley2008's Avatar
Trailer: 2012 Escape 19' with Ram Hemi or FJ Cruiser
"Egg Camper" air conditioning condensate...
It seems that the "Egg Camper" brand of camper, as well as some Scamp models, have their air conditioning units "inboard" in that they are within the confines of the camper. I'm thinking of modifying the set up by installing an exterior hatch cover that will enclose the opening in the winter and non use times and open while using the air conditioning. The existing set up can allow winter air intrusion as well as insects in the summer.
The condensate drain is another issue and wondering the best way to address that issue? With units inboard there is always the possibility of water on the floor if not properly level. Seems there needs to be a better solution.
Old 05-02-2011, 06:05 PM   #2
Trailer: 2007 Eggcamper
The A/C grill is metal. What if you just used a magnetic pad (like the car signs) to cover over the grill in the cold weather. Would be quick and easy. Just don't forget to take it off before trailering.
Art
artspe is offline   Reply With Quote
Old 05-02-2011, 06:10 PM   #3
that is exactly what Jim Palmer suggested and something he has been toying with for his teardrop. any suggestions as to where- maybe I can order 2-3 and the other Eggers can get them at the Poconos in July? save on shipping
Old 05-02-2011, 06:13 PM   #4
Trailer: Uhaul CT-13
Ohio
There is a thread on interior AC installs, including making an insulated duct to the outside grate. I did a simple window install on my CT, it installs and removes in less than 5 minutes.
A/c
https://picasaweb.google.com/brysthe...at=directlink#
Panoz77 is offline   Reply With Quote
Old 05-02-2011, 06:51 PM   #5
You should be able to have one made at a sign place locally or on-line. Have it covered in white vinyl and it should blend in well.
Art
Old 05-10-2011, 12:31 PM   #6
Trailer: Two Trillium Jubilees and a Trillium 1300
Send a message via MSN to Bill Reilly
Air Conditioner Cover
Jim
I installed an air conditioner in the rear wall of my Trillium. I made a wooden cover and hinged it to the rear bumper. I had to modify the spare tire bracket to accomodate this but it has worked out very well.
I plan to make a mould and fabricate a fibreglass cover to replace the wooden one. This will have to wait until this fall or winter. Too much camping and golfing to be done over the summer to allow me to take this next step. !
I posted some views of this in on the web. The link is:
picasaweb.google.com/billreilleh Click on AC Cover
I have many other views of this modification so if you need more let me know and I'll upload shots of the construction process.
Bill Reilly
Bill Reilly is offline   Reply With Quote
Old 05-10-2011, 02:36 PM   #7
honda03842's Avatar
Name: Norm and Ginny
New Hampshire
We had an in board AC on the Casita 16 this summer. It easily handled 98 degree weather.
A way to deal with the water and not worry about level is to have a surround like ones often used under washers in case of over flow.
The venting on the Casita was aluminum so magnets would not stick to it. The inside of ours was lined with screening to exclude mosquitos as did the refrigerator vents, doubt that was factory. While driving and in winter they had a backed piece of vinyl attached in four corners.
Norm
Old 05-10-2011, 03:33 PM   #8
Bill,
I could not get your link to work....
Old 05-10-2011, 03:54 PM   #9
Bill,
Jim
Sorry - I made a typo in the web address ! Left the y out of reillyeh
Should be:
picasaweb.google.com/billreillyeh When it opens click on AC Cover
Old 05-10-2011, 05:22 PM   #10
Good job Bill, i like that cover. Looks like you had to remake your spare holder also-what work we do for some cooling. The a/c in the Egg is recessed about 12" behind a grill that bothers me, bugs and weather are my 2 big fears. I contacted a magnetic sign person who is working up a price. The condensate just runs out the opening. Ideally, I'd like to install a hatch cover that is secure. Looking into that also. Any ideas on custom made hatch covers like on boats?
Old 05-11-2011, 07:44 PM   #11
Here's a direct link to Billy Reilly's pictures, he put the website in as text in his post, not a link: Picasa Web Albums - Bill Reilly
Double Yolk
1988 16' Scamp Deluxe
Old 05-23-2011, 06:59 PM   #12
Well, I ran my a/c all night this weekend, not a drop of condensate? I do not know where it is going so I'm pulling the a/c out this week to try and find out the answer. Jim Palmer said it was supposed to run out the side, under the vent. Nothing there, nothing inside, nowhere. A mystery in search of an answer.
Old 05-24-2011, 07:12 AM   #13
Bill Robison's Avatar
Name: B & N
Trailer: View
Jim -
It's a bit of a mystery to me as well, but if you think back to some of the old-style home refrigerator units. They had a tray to hold the condensate - then as the compressor generated heat (during the cooling process) that hot air was directed to flow over the condensate in the tray and it would cause it to evaporate. Perhaps the EggCamper is similar - and the exhaust air evaporates the condensate until it reaches a certain saturation point and can't keep up - at that point the condensate begins to collect and has to be expelled in some fashion?
I have yet to dig deeply into my A/C set-up to see what is happening.
Bill
'Do not go where the path may lead, go instead where there is no path and leave a trail.' - - Ralph W Emerson
Bill Robison is offline   Reply With Quote
Old 05-24-2011, 09:25 AM   #14
Roger C H's Avatar
Smile Trillium Jubilee
How long is your Jubilee?
It does seem unusual that Trillium would build a trailer with the sharp corners when they had several models with rounded. Maybe the sharp corners give more room inside?
eggcamper
Casita air conditioning condensate drain James Wilson General Chat 8 04-19-2009 09:15 PM
FOUND - Looking for 16' or 17' "egg style" trailer Ella R Wanted: Molded Fiberglass Travel Trailers 2 01-31-2009 06:11 PM
Scamp 13' camper with air conditioning! - $6400 Kevin K Classified Archives 6 01-06-2008 07:27 PM
SOLD 13ft Play-Mor II For Sale "The Brown Egg" Susan Tiller Classified Archives 3 01-13-2007 03:48 PM
new egg "camper".......... julian General Chat 5 12-17-2006 06:53 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
