Electronic Stove Ignitor - Fiberglass RV
Old 04-27-2009, 03:12 PM   #1
Joy A's Avatar
Well here's my latest mod to my Little Marshmallow. I added an electronic ignitor to the stove. This is a project that I'd had in mind for sometime. My friends Ted and May had given me this idea which they added to their Scamp. I previously purchased necessary compontents to complete the mod but one of the electrodes had to be modified because it wasn't long enough. It was a task that I simply con't get right.
The other day I was in WalMart looking at accessories for my home grill and an ignitor kit jumped out at me. It's made by Grill Care and is a universal electronic ignitor kit for aboiut $26. What actually caught my eye was 2 long electrodes, the kit comes with 3 as it's made for big grills. Out the store I went with my new purchase.
Today I took a scrap piece of aluminum and bent it as the following picture shows to accept the electrodes.
I then cut the electrodes to length and bent them as the instructions stated. The hardest part was the adjustment so the electrode was far enough from the burner flange that it didn't spark there as well as from the stove top.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 04-27-2009, 03:20 PM   #2
Joy A's Avatar
I continued on by drilling a hole through the wall of the stove, running a non-combustible sleeve (which came with the kit) through it and then snaking the 2 wires through the sleeve.
Once that was done I drill a 13/16 inch hole through the cabinet and affixed the ignitor's spark generator. I plugged the wires into the back of the generator, capped the extra slot for the third electrode, wound up & zip tied the excess wire and added the battery.
All done.
The ignitor's starter button is the black button left of the silverware drawer.
Joy A. & Lily
and "Puff", too
Old 04-27-2009, 05:04 PM   #3
james kent's Avatar
Trailer: Boler 1984
Now That's neat!
No more searching the drawer for a light or a match and no more burning the hair off the back of your hand.
Old 04-27-2009, 07:02 PM   #4
Joy A's Avatar
James, you're correct. I happen to use a piezo lighter that simply sparks, I've never cared for the ones that have a flame and are I think filled with butane. I've always figured the piezo was safer as it contains no volitile substances. But that's just me, I know lots of you folks use them and that's OK.
My piezo lighter looks like a gun and had a nice spot on the side of the stove cabinet until I added the counter extension under which sits my toaster/oven. Now I can do away with my piezo.
I will still carry matches for campfires. Oh, in thinking about outside fires, maybe I should keep my piezo for the campstove that I will be using more now that I have a "Y" and a long hose the big propane tank. I think I'll go out right now and put it in with the campstove.
Joy A. & Lily
and "Puff", too
Old 04-27-2009, 08:18 PM   #5
Anne H's Avatar
Trailer: Escape 17 ft 2006 / 2005 Honda Pilot
Cool Mod! I had one of those universal igniters for my BBQ but could never get it to work - maybe I'll repurpose it.
Anne H and Fay Wray, the cat | Portland, OR
en Plein Air (2016 19' Escape; 2016 Honda Pilot )
http://rightbrainrightlane.blogspot.com/
Anne H is offline   Reply With Quote
Old 04-28-2009, 06:09 AM   #6
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Nice mod! I considered this also. Even bought the ignitors. I seem to have a similar stove as you but my tray hugs the burners much closer and I didn't have the room to get the probe up to the burner without grinding away on the enameled tray. Couldn't bring myself to do it.
I'm going to go back out and study it some more. I wonder if that enamel stove touchup paint is heat resistant enough to work in that area (after grinding a bit of a notch for clearance).
Good job!
Quando omni flunkus, moritati
Old 04-28-2009, 09:41 AM   #7
Joy A's Avatar
Thanks Steve,
I'd say that when you look straight down at the burner there is about a 1/2 inch gap between the lower burner flange and the enamel cooktop opening. When the electrode comes up through the gap it's about mid way between the two. So roughly 1/4 inch from both which was just enough to stop the electrode from arcing to them.
I should have taken a picture of the electrodes before installed and cut them. As you can see in one the my first pictures the electrode sparker wire extended out of a white piece of enamel or something. The sparker was about and 1 1/4 inches long. It was this longer sparker that I needed to get it through the gap. The original components that I had trouble with had a very short sparker so it had to be extended that's what I just could get correct. With the short sparker there wasn't enough room to get it to the burner. Hope this is clear as mud.
Joy A. & Lily
and "Puff", too
Old 04-28-2009, 06:36 PM   #8
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
This is a great mod, and I'd do it in a minute if I ever used the stove anymore! (Corrupted by the microwave.) Here's the igniter at the WalMart online store for $17.96: http://www.walmart.com/catalog/produ...uct_id=8587363
Patrick M. is offline   Reply With Quote
Old 04-29-2009, 05:22 AM   #9
Joy A's Avatar
What was I thinking!! I found my receipt and I paid $17 even for the kit at the store.
Patrick, yes that's the kit.
I used the 2 long electrodes, 2 wires and the generator, heave hoing the rest. The electrode in between the 2 wires in the picture is just way too short to use. Didn't need the metal box or bag with screws etc.
Joy A. & Lily
and "Puff", too
Old 05-01-2009, 09:15 AM   #10
The Hobo's Avatar
Trailer: 1976 Triple E Surfside
Attachment 19750
Once that was done I drill a 13/16 inch hole through the cabinet and affixed the ignitor's spark generator. I plugged the wires into the back of the generator,[b] capped the extra slot for the third electrode, wound up & zip tied the excess wire and added the battery.
All done.
Attachment 19751
Did you not have to use that 3rd connection to a ground screw,??
I just picked up the kit a Wall Mart yesterday for 14.99,
and hope to have time to install it this weekend.
Thanks for the great info BTW.
1976 Surfside Tripple-E
The Hobo is offline   Reply With Quote
Old 05-01-2009, 09:43 AM   #11
Joy A's Avatar
Ulysse,
The kit said when using 2 electrodes, use the third to ground. I was thinking that if I had 3 burners there wouldn't be a fourth to use as a ground so why am I worrying about grounding. I didn't cut the electrode off to ground the wire. I simply capped the jack.
I guess I could ground it.
Joy A. & Lily
and "Puff", too
Old 05-03-2009, 10:51 AM   #12
The Hobo's Avatar
Ulysse,
Well, I got it all done today,
and it looks/works great.
I grounded the 3rd plug, because I actually got a small shock from the stove while testing the ignitor,
so I decided to use the 3rd plug to go to a ground.
All is good now.
Thanks again for posting the great Idea.
Old 05-03-2009, 12:40 PM   #13
Joy A's Avatar
Ulysse,
You are very welcome. I know you'll enjoy it for years to come, I sure will.
Joy A. & Lily
and "Puff", too
Old 05-08-2009, 06:49 PM   #14
Gilles D's Avatar
Trailer: Casita Spirit Deluxe 17 ft 2001
Quebec
I think I have seen a similar mod in Janary on the Casita forum but the author install the complete system in the stove here the link :
http://www.casitaforum.com/invboard/index....pic=4362&hl
Well done Joy A
Gilles & Josy
Casita 2001 17 SD
"The EGGxile"
Gilles D is offline   Reply With Quote
Electronic Brake Suggestion Pamela K Towing, Hitching, Axles and Running Gear 10 04-14-2009 08:41 AM
water heater electronic ignition failed Randy Magee Problem Solving | Owners Helping Owners 4 11-11-2008 10:06 PM
Electronic Gadget Byron Kinnaman General Chat 21 07-01-2006 06:16 AM
Water Heater Re-ignitor Steve L. Modifications, Alterations and Updates 8 12-16-2005 03:27 PM
Fridge Auto-Ignitor Legacy Posts Modifications, Alterations and Updates 1 09-30-2002 08:18 AM
