07-03-2019, 10:58 PM
Utah
Eliminate the roof vent?
There are a few modifications I am thinking of doing while I repair and renovate my Scamp 13. I had, for example, debated removing the sink and water system, but then watched a van conversion video where the guy's biggest gripe was no water or sink for simple things like brushing teeth and washing hands. I was pretty convinced, so I think it will stay (though I might simplify it).
On to the point. I am considering doing away with the roof vent. I've seen people have issues with it (leaks, breakage), I hit my head on the handle, and I plan on running a window AC all the time, so I don't think I'd use the vent much for temperature control. I understand it also serves as an emergency exit... but I feel like I could kick out one of the big windows if I had to. Also, it will fit in my garage without the vent, and be more aerodynamic as well.
Am I crazy? I'd love to hear some experienced perspective (nicely please!)
07-04-2019, 01:05 AM
Trailer: Trails West
You can remove the handle, you won't need it if you are not going to open it. But if you need to put it in the garage then just take out the ceiling vent. Make it a reversible process with a flat closure panel instead of glassing in the hole. That way you can change your mind later if you want to.
07-04-2019, 02:37 AM
Mid Left Coast
man, on both our casita 16 and our escape 21, when boondocking, the ventilation fan is a life saver.
i just got home today from 5 nights at a star party... i was up late outside each night, and went to bed just before dawn, then slept til 11 or noon. at 6 or 7 am, when the sun rose and it warmed up, I'd wake up a bit, shut off the heater, and turn on the fan, then lay back down half nekkid under the fan without blankets, and it would keep me cool ....
07-04-2019, 05:53 AM
Trailer: Bigfoot 25 RT
While I rarely use the fan, the vent stays opened most of the time; especially if it’s warm outside.
Hot air rises and an opened vent gives it an exit.
The vent is always opened while driving. Keeps the trailer air nice and fresh.
07-04-2019, 06:09 AM
This of course goes against the instructions and recommendations for a few reasons including increased likelihood of breakage and allowing more dirt inside.
But back to the question.. yes you are crazy. But only because you plan on "running a window AC all the time."
I'm pretty sure you will want a roof vent, and one with a fan also. But even if you really do never use it, its still good to have to keep the camper ventilated when in storage to reduce issues with moisture and mold. Of course a cover or a carport / garage would be needed to keep the rain from coming through the vent. The Fantastic Fan roof vent/fans can have a cover added and the Maxxair ones come with built in rain covers.
07-04-2019, 06:31 AM
"This of course goes against the instructions and recommendations for a few reasons including increased likelihood of breakage and allowing more dirt inside."
The vent has a cover. Standard issue with my Escape. No dirt problems over the last 20+ years with a variety of covered vents.
To each his own.
07-04-2019, 06:38 AM
I would get rid of A/C before I got rid of a ceiling vent/fan as we are more often not connected to 120V so the A/C can't get used. Besides, I avoid super hot climates for camping as much as possible. Our fan gets a lot of use mostly for drawing hot/warm air out of the trailer during the day and at night. Turned low, our MaxxFan is very quiet too. Turned high it moved a lot of air.
Even if you are connected to 120V and can use the A/C, I like the fan for moving fresh air into the trailer.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
07-04-2019, 07:53 AM
I agree with Jim B , the fan is too valuable to eliminate
The fan allows you to have positive ventillation when camping without hookups
07-04-2019, 09:13 AM
I installed a boat solar powered fan in my van which I use for short, overnight trips, it keeps the van smelling fresh and has not leaked since I installed it in 2008. It does not add a lot of height (about 2") in ground clearance. Just might be your solution and it does not run the battery down.
07-04-2019, 09:23 AM
Trailer: 1983 Casita & 1972 home-built
I have been using a couple of standard flat 14 x 14 roof vents with no fan or rain shield in my home-built for decades. They only stick up a couple inches, and don't admit much rain even when while opened a useful amount. I have driven thousands of miles with the rear-facing one open a couple inches.
If raindrops getting through are a big problem, you could set a rain shield in place while parked and take it off while moving. Heck, even a plastic produce box with one side cut out would do that job.
Indoor Air Quality turns out to be very critical for good health. Anything you can do to improve ventilation indoors is well worth doing.
07-04-2019, 09:32 AM
Trailer: Casita 17 SD
Keep the Vent we always crack the vent when sleeping nights. Not healthy to remove it. We also use the fan when needed when warmer during morning cooking time, or afternoon napping.
07-04-2019, 10:18 AM
Trailer: Scamp 19
Roof vent
Lot people talking about the fan. I did not see any mention of a fan, just a vent.
07-04-2019, 12:25 PM
Mid Left Coast
only RV roof vents I've seen have had fans in them, and you can't have a fan without a vent for the fan to suck air in our out, so....
07-04-2019, 12:40 PM
Trailer: Scamp 19
Roof vent
My vent does not have a fan and I have never had a trailer with a fan vent.
07-04-2019, 12:42 PM
I have only owned 4 trailers and they all had fans in the ceiling vent. Seems strange to me not to have a fan, as they really help move the air.
2017 Escape 5.0 TA
07-04-2019, 12:46 PM
Mid Left Coast
huh, even our late 80s Starcraft tent trailer had a fan in its roof vent.
07-04-2019, 04:16 PM
If lots of people are talking about the fan then there is A LOT of mention of a fan. And the reason is that the OP asked for advice and a roof vent with a fan is much better than one without. We're here to help him get a camper he enjoys.
Well it makes a big difference, hence all the people recommending it.
07-04-2019, 05:27 PM
Why would you not want water or air circulation? If you don't want anything in your trailer why not just use a tent? A/C is not as important as water and a toilet. I just don't understand why Scamp owners remove all the stuff in their trailers.
07-04-2019, 05:33 PM
Trailer: Casita 16ft.
I've found and repaired several leaks in our 16ft. Casita but nary a leak in the vent as of yet. My Casita is an older model so the ceiling height isn't as high as the newer models. I can sympathize with hitting one'e head on the lifting crank. I have toyed around with the idea of enlarging the hole slightly before fiberglassing in a small bump in the roof to allow the vent to be raised with the crank at least flush with the interior ceiling. But I have too many other projects going on so that one is on the back burner.
07-04-2019, 05:49 PM
Originally Posted by Jann Todd
... I just don't understand why Scamp owners remove all the stuff in their trailers.
Originally Posted by Nor Cal Mike
I've found and repaired several leaks in our ...
Well.. question asked and answered. But even if it was not meant to be the answer to the question of why people take things out, I do think that leaks of various types are one of the main reasons that people remove things. I removed my water heater after the shutoff valve developed a leak and I realized that I did not need the water heater. People remove propane because of a fear of leaks (often more fear than is warranted). People remove roof vents and since I have two, I will seal up the larger one when the time comes.
But somethings are worth taking the chance of a leak and I think a roof vent is one of them.
