[QUOTE=Wallo;462522]Greg: Does the Roto Zip have a blade, or is it a drill bit type cutter? I have a Ryobi hand held router, could that be used with the correct cutter?
Wallo,
Sorry I didn't get back sooner, but to answer your question; The Roro-Zip blade, while appearing to look very similar to a standard drill bit, is actually a rotary abrasive cutter which cuts laterally through objects as opposed to drill bits which are limited to penetration only. If Ryobi makes suitable rotary cutting blades similar to Roto-Zip blades, I'd say that would be great. I don't believe the standard Roto-Zip blades would tighten up in the Ryobi's bit chuck, but I haven't seen one up close. Most router bits have a larger diameter shank on them.
