Ensolite - Page 2 - Fiberglass RV
Old 05-01-2014, 11:04 AM   #21
Trailer: 2010 Scamp 16
You know the old sign from the repair shop?
Labor Rate:
$10 per hour.
$15 per hour if you watch.
$20 if you offer advice.
$40 if you worked on it first and only brought it here after you messed it up.
Too bad you can't back charge labor on the go-fer now rigging that was done. But as you say, once you have it done right it will be an accomplishment to be proud of and enjoy.
Old 05-01-2014, 11:49 AM   #22
Roy in TO's Avatar
Originally Posted by Carl Brooks View Post
For my own knowledge, how were the water lines run from the factory?
I have yet to see an original toilet from that era from Tri-Fab.
It was simplistic or rustic, your choice.
A fresh water tank was under the curbside rear bench, with filler below the window. A line ran along the floor under the ensolite at the rear then under the rear streetside dinette bench to the kitchen cabinet. A short city water line ran from the streetside to the tap. The grey water either ran through an open hose through the floor by the streetside wheel well or later models to a capped connection behind the lower kitchen cabinet.
Old 05-02-2014, 07:08 PM   #23
Carl Brooks's Avatar
Trailer: 73 Tri-Fab
Greetings all,
How about the water line to and from the water heater?
Please tell me they were not copper tubing run under the trailer.
I believe my best bet for replacement of all water lines will be braided flexible stainless steel. Any thoughts?
The closeup picture is the vent fan over the shower. The top has completely cracked and fallen of. Anyone seen one like this?
Carl
Carl Brooks is offline   Reply With Quote
Which ensolite Kent I Problem Solving | Owners Helping Owners 3 02-21-2012 03:36 PM
Sagging Ensolite Dawn S Problem Solving | Owners Helping Owners 4 07-15-2009 01:54 PM
Which ensolite info Kent I Forum Admin, News & Announcements 1 07-07-2009 10:46 AM
To remove or just paint ensolite ursulap Problem Solving | Owners Helping Owners 11 07-04-2009 05:43 PM
Ensolite Melinda M Problem Solving | Owners Helping Owners 6 06-24-2009 09:33 PM
