Evaporative cooler - Fiberglass RV
Old 06-02-2014, 03:51 PM   #1
cmalla's Avatar
Trailer: Hunter Compact II
Evaporative cooler
Anyone have any experience with Turbocool evaporative coolers for rvs?
cmalla is offline   Reply With Quote
Old 06-08-2014, 10:42 PM   #2
Virginia
I don't have experience with that one specifically, but evaporative coolers are the poor man's air conditioner. They're also called "swamp coolers". They're cheap, but they don't work all that well, even under ideal conditions.
You need to be in a dry climate. We're talking desert conditions... like 30% humidity or less. I see you live in AZ, so that shouldn't be a problem. They use a lot of water, usually in the range of a gallon per hour, so you need to have that on hand. And they only cool the air 15 or 20 degrees below ambient. So if it's 95 degrees outside, you might be able to cool it down to 80.
On the plus side, they're quiet, they don't use much power, and you can run them off of solar panels.
mmcwhort is offline   Reply With Quote
Old 06-08-2014, 11:36 PM   #3
Borrego Dave's Avatar
You are right Mike about only dropping the temp maybe 20*. I've never had a swamp fan in an RV but had one in the house I had in AZ in the 70's. The 20* drop from outside to inside was fine. If you were inside and got a bit warm, go outside for a few minutes and go back inside.....cool.
The water supply would be something to be concidered but I do think a swamper would be good for people traveling in the southwest.
Old 06-09-2014, 12:14 AM   #4
Unhappy
When I bought my Fiber Stream it had an older version of an evaporative cooler on the roof. The shroud looked exactly like an RV air conditioner. The exception was the permanent hose that hung on the side of the trailer, to screw onto a faucet to get water up to the reservoir. If I left water in the reservoir while traveling it leaked out as if I had left a roof vent open in the rain. I only did that once; I never wanted to repeat the clean-up of every interior surface! The next time I tried to use it the float valve got stuck and it leaked inside again! The exterior hose also drained the reservoir on the roof. It took 1/2 an hour to gravity feed the water out. I never put water in it again. Later I took it off and put a Fantastic Fan in it's place.
Evaporative Cooler in Scamp 13? morz4 Problem Solving | Owners Helping Owners 0 05-27-2014 02:39 PM
U-Haul Swampbox Cooler, $100 Steven Tonnesen Classified Archives 0 07-05-2009 10:20 AM
Swamp Cooler Successes? Laurie Problem Solving | Owners Helping Owners 4 06-27-2009 01:02 PM
Help me!!! (evaporative systems) pla-cooler gökhan Problem Solving | Owners Helping Owners 8 08-08-2008 03:24 AM
12 Volt Evaporative Cooler Nancy A. Care and Feeding of Molded Fiberglass Trailers 7 06-04-2008 08:02 PM
