Today I finally got annoyed enough with the trouble of draining my water tank for the winter. Draining my tank required the following:
* Lift up the bed
* Lift up the bed plywood board support
* unscrew the under-bed floor and remove
* fit my hand into the tiny, three inch space where all the water connectors meet the tank, then open the drain cock.
I figured I could do better with a simple mod. The idea: run a short pipe nipple through a hole drilled in the bottom of the camper. Attached the drain cock for easier access.
Tips:
* buy several sized parts if you aren't sure which size you'll need
paint a mark to show the "open" position on your drain cock (before you install)
