Exterior sanding/prep advice - Surfside 78 - Page 2 - Fiberglass RV
Old 03-06-2015, 11:29 AM   #15
hudman's Avatar
Trailer: triple e
Thanks guys! Definitely a HUGE labor of love. Still have so much more to do and I think I might be taking way too much time with it but I can finally see the finish line. Lots of advice and help from these forums contributed greatly!!
hudman is offline   Reply With Quote
Old 04-10-2015, 08:34 AM   #16
hudman's Avatar
Trailer: triple e
Name:	ImageUploadedByFiberglass RV1428676021.896502.jpg
ID:	82429Click image for larger version
Name:	ImageUploadedByFiberglass RV1428676049.278089.jpg
...started the kitchen area last weekend. Hope to have all the wood work finished this weekend.
Old 04-10-2015, 08:38 AM   #17
hudman's Avatar
Trailer: triple e
Name:	ImageUploadedByFiberglass RV1428676631.221085.jpg
ID:	82435Click image for larger version
Name:	ImageUploadedByFiberglass RV1428676662.670679.jpg
....and a shot of the ceiling in process I attached a few weeks back.
Old 04-10-2015, 09:25 AM   #18
Looks real good and well thought out. How was the smell of that paint while it was curing? How long did it take to set-up?
Old 04-10-2015, 10:05 AM   #19
hudman's Avatar
Trailer: triple e
Are you referring to the interior paint? If so, it was a acrylic latex bathroom paint I put on with a gun. Only smelled for a couple of days. I'm going to be staining and varnishing the interior in a few weeks and I know that will smell for a while so the last things to go in will be the windows and door. I painted the interior in a few hours.... What took a while was putting in the reflectix and then the closed cell foam on top. Eeks!
Old 04-10-2015, 10:56 AM   #20
I was referring to the exterior polyurethane. I know while spraying these some of them are obnoxious until cured.
Old 04-10-2015, 11:00 AM   #21
hudman's Avatar
Trailer: triple e
Oh actually not bad at all. The odour lasted a few days and now obviously nothing. It's a very durable paint system I used...a marine grade, etc...
Old 04-10-2015, 11:02 AM   #22
hudman's Avatar
Trailer: triple e
System 3 gel coat... I sprayed inside a small Quonset wearing a proper canister mask. Opened her up after and smell was gone In a couple days.
Old 04-21-2015, 12:32 PM   #23
Trailer: Coachman
Manitoba
Originally Posted by hudman View Post
So I ended up taking most of the top coat off the whole trailer, started with an 80 grit, and finished with a 120. Primer went on amazing as well as the final 2-3 coats. I ended up using the 'system 3' gel coat paint system. I did the whole paint job with a spray gun and it worked out well. Next, windows are installed and we start with the interior... pics to follow as always
looks great, good job. well done.
Evinger1 is offline   Reply With Quote
Old 05-19-2015, 05:59 PM   #24
hudman's Avatar
Trailer: triple e
More progress pics... For those whom are interested. Put in some cool brake/signal lights this weekend, led lights in the interior roof, switches, outside shower, water service, cord box, and marker lights. Varnished the wood interior with about 6 coats to make it glass like.....goal is to have it ready for first weekend in July. More pics to come...Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079761.581882.jpg
ID:	84116Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079790.848839.jpg
ID:	84117Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079811.364172.jpg
ID:	84118Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079839.230881.jpg
ID:	84119Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079861.764741.jpg
ID:	84121Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079883.680387.jpg
ID:	84122Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079900.881416.jpg
ID:	84123Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079934.163340.jpg
ID:	84125Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079950.764307.jpg
ID:	84126Click image for larger version
Name:	ImageUploadedByFiberglass RV1432079964.314668.jpg
Old 05-20-2015, 12:00 PM   #25
Nova Scotia
Beauty!
What is the metallic panelling?
I'm new here - if we pull out all of our cabinetry can it go back in? Do people build their own primarily for customization? Is weight a factor? Can I expect our cabinetry to have some kind of issue due to age (1975) or is it usually fairly solid - I'm assuming its fiberglass...
We have a paint design in mind and I'm thinking paint with decals would be the way to go, or a vinyl wrap but that could be too expensive.
Thanks
Jeannette in NS is offline   Reply With Quote
Old 05-21-2015, 10:57 AM   #26
keithfwhite's Avatar
Trailer: Triple E
Looks great! I'm in the same process with my 78 surfside. Rebuilding the interior now. Click image for larger version
Name:	ImageUploadedByFiberglass RV1432225788.917290.jpg
ID:	84177Click image for larger version
Name:	ImageUploadedByFiberglass RV1432225806.380248.jpg
keithfwhite is offline   Reply With Quote
Old 05-22-2015, 10:25 PM   #27
hudman's Avatar
Trailer: triple e
Originally Posted by Jeannette in NS View Post
Beauty!
Thanks
Hello and welcome!
Not metallic paneling, just birch plywood stained with mixture of stains I threw together and varnished several times.
The window frames were stained to give a 'weathered look'. Can't see them really in any of these pics but it looks great. Still not sure if I'm going to keep it or not.
I have to be honest with you.... I don't know a lot of what was originally in my trailer, as it was an empty shell when I bought it, but I know some did come with fiberglass cabinets and apparently you can put them back in. I used a combination of pine and cedar framework. Fiberglass "Tabbed" my whole interior so I would have something to attach the cabinets to. My interior is fairly light. I know these surfsides were rated to weigh about 1500lbs when filled and ready to go.
Hope this helps... There is so much info on this site to help you out. I knew nothing originally and pulled a lot of ideas and solved a lot of problems by perusing the threads.
Good luck!
Old 05-22-2015, 10:28 PM   #28
hudman's Avatar
Trailer: triple e
Originally Posted by keithfwhite View Post
Looks great! I'm in the same process with my 78 surfside. Rebuilding the interior now. Attachment 84177Attachment 84178
Hey!
I've been following your progress. I would have been done last summer myself but I have two kids below the age of 19 months.....sooooooo, I guess I'm a little behind on the trailer reno.
The rate you're going you're going to be done in a couple weeks!!
surfside
Sanding contours Cat futrell Problem Solving | Owners Helping Owners 7 08-17-2013 04:43 PM
exterior access hatch and exterior shower aimeelightsey General Chat 36 10-06-2012 03:15 PM
Question Re sanding damaged area before painting elwynevenstar Modifications, Alterations and Updates 5 10-14-2011 08:10 PM
Sanding Fiberglass Pamela S. Problem Solving | Owners Helping Owners 11 04-07-2010 11:16 PM
"Sanding your GROUND" Alf S. Problem Solving | Owners Helping Owners 3 05-30-2007 08:51 PM
