Exterior sanding/prep advice - Surfside 78 - Page 3 - Fiberglass RV
Old 06-14-2017, 10:49 AM   #29
Trailer: Boler 1975
It's been a while since you did your exterior paint job but I'm wondering if you could tell me how it held up? I'm planning on putting on the exact same SystemThree this weekend. Also, did you use their Yacht Primer and the WR-LPU or just the WR-LPU over the sanded fiberglass/gelcoat combo?
Colleen
cbee7899 is offline   Reply With Quote
Old 06-14-2017, 01:16 PM   #30
hudman's Avatar
Trailer: triple e
Colleen
Hello Colleen,
It's worked out very well. I've had no issues as of yet with fading or bad wear. Keep in mind though that I always keep it washed and covered when not in use.
I did use the primer before hand as it helps with filling in small imperfections, etc..So Yes, I used the complete system. I also sprayed everything on using a simple spray gun anyone can buy at Napa, ect...
After a week or so I ended up looking for some kind of wax that would give it that varnished wet look. I couldn't find any and I ended up finding a thread on using 'Zep wet look floor finish'....yes, that's correct. lol. I put on 5 coats originally and every year I hit it with another. Gives it a great wet appearance and helps protect it. You can grab that at Home Depot, I believe.
Hope this helps!
hudman is offline   Reply With Quote
Old 06-18-2017, 03:59 PM   #31
Trailer: 1978 surfside triple e
BC
Painted mine with Cloverdale high gloss enamel marine paint. Sanded once with 80 grit using an orbital sander, painted using the roll and tip method (google it). No primer used and worked well. By no means a proffesional job but as amateur goes it looks good.
Erik F is offline   Reply With Quote
Old 06-20-2017, 10:14 AM   #32
Trailer: currently shopping
Arkansas
Originally Posted by hudman View Post
Attachment 82429Attachment 82430
...started the kitchen area last weekend. Hope to have all the wood work finished this weekend.
Where did you get your back splash from?
Hitch is offline   Reply With Quote
Old 06-20-2017, 11:00 AM   #33
hudman's Avatar
Trailer: triple e
I believe I bought the backsplash at either home depot or lowes. Used something like liquid nails to get them to stick! Still on today after lots of use.
Old 07-04-2017, 07:41 PM   #34
Trailer: triple e surfside rm-14
tail lights
Love to put the same tail lights on my surfside. Where did ya get em?
Taking the path Lester travelled.
billyjcoombs is offline   Reply With Quote
Old 04-14-2018, 01:33 PM   #35
Hi there, looks like you did an amazing job!
I'm prepping to repaint our '73 Trillium and have a couple additional questions for you, if you don't mind:
1) Were you able to find system three paint at a chain (noticed you're also in Canada) or did you have to go to a specialty store / order it online? I havent seen it locally.
2) Did you use any products between sand and prime to clean the surface or just soap and water + rinse?
3) Do you remember how much paint you used? 1 Gallon primer? Were you able to get your 2-3 coats with 1 gallon of each white and blue?
4) I noticed the system 3 paints include a "cross linker" that is supposed to increase hardness / durability. Is this something you mix in for all coats or just the final coat?
5) I'm a little new to painting with an spray gun - were you able to rent an air compressor / did you already own one, or how does that work? I noticed from System Three's website that "SilverTip Yacht Primer can be applied by brush, roller, or spray. For spray application, HVLP equipment is recommended." did you use a HVLP system ?
Great idea with the Zep Wet Floor finish... looks awesome!
Thanks and all the best,
Scott
Hello Colleen,
Hope this helps!
Element89 is offline   Reply With Quote
surfside
Sanding contours Cat futrell Problem Solving | Owners Helping Owners 7 08-17-2013 04:43 PM
exterior access hatch and exterior shower aimeelightsey General Chat 36 10-06-2012 03:15 PM
Question Re sanding damaged area before painting elwynevenstar Modifications, Alterations and Updates 5 10-14-2011 08:10 PM
Sanding Fiberglass Pamela S. Problem Solving | Owners Helping Owners 11 04-07-2010 11:16 PM
"Sanding your GROUND" Alf S. Problem Solving | Owners Helping Owners 3 05-30-2007 08:51 PM
