Fabric grade to reupholster seat cushions? - Fiberglass RV
Old 04-16-2011, 07:49 AM   #1
Cyndivg11's Avatar
Trailer: 1984 FiberStream
I went to: Foam Mattress Pads Memory Foam Platform Beds & More - a great site to choose new foam and fabric to redo the old 70's look cushions in my 84 Fiberstream. When I search through the fabric, there are fabric grades. ie: 15, 20, etc. Doe anyone know a 'range' of thickness or fabric grade the fabric should be on the seat cushions?
Also, I'm assuming the flexible ceiling curtain tracks, Curtain Tracks & Drapery Track Systems - Curtain Tracks, are tracks I can use to curve around the corners of my fiberstream?
Thanks.
Cyndivg11 is offline   Reply With Quote
Old 04-16-2011, 08:10 AM   #2
Cyndi, sorry I can't help with the upholstery questions, but here's another source for flexible curtain rods for shower curtains. It comes in brown too. Comparison shopping is always a good thing!
Flexible Ceiling Curtain Tracks
Old 04-17-2011, 08:30 AM   #3
Trailer: Casita 16'
Wisconsin
Fabric For Cushions
Thanks.
Cyndi,
I've covered lots of seat cushions. You need a fabric that will stand up to much use. It should be tightly woven, darker in color, a pattern (not solid) will hide spots, and have some bulk to it. A cotton/polyester blend will hold up well, if it is heavy enough.
Reasonably priced fabric for covers can be found @ liquidation/end of lot shops. Try the back tables in a fabric shop, watch for 40% off sales, as you are going to need alot. Ask at an upholstry shop for discontinued supplies, etc.. Fabric that is used for covering outdoor furniture should stand up well to lots of use. I found a couple of co-ordinating fabrics @ a Walmart for $4.00 a yard.
I used one pattern for the top and sides, and the other for the bottom; making it reversible.
If you are going to use welting, I encourage you to choose a dark color for it, as that will get the most use. Again, tightly woven.
If you are a novice, seek advise from someone who has made covers for cushions. You should be able to check the fabric and feel it to decide if you will use it or not.
Best wishes as you work with your project. Mona Simpson
monasimpson is offline   Reply With Quote
Fabric For Cushions Highway68 Problem Solving | Owners Helping Owners 15 08-14-2010 09:38 PM
Indoor/Outdoor fabric for cushions? Amy M Care and Feeding of Molded Fiberglass Trailers 11 12-17-2009 07:46 AM
New seat cushions shane n Modifications, Alterations and Updates 2 03-18-2009 07:02 AM
Tapered Seat Cushions Loren G. Hedahl Modifications, Alterations and Updates 1 09-28-2006 08:35 PM
Fabric for seat covers. Gina D. Care and Feeding of Molded Fiberglass Trailers 19 11-14-2005 01:47 PM
