06-17-2018, 08:58 AM
Trailer: Scamp 2017 16-ft SD / FB
Fan in refrigerator
Looking for info on the installation of a 12v muffin fan in 120/propane Scamp refrigerator.
I was reading in DoItYourself RV about getting better cooling with the addition of a 12v fan. This seem like a great idea to increase refrigerator temp but not freeze the food. In Texas it is hot, the temp stay around 39-40 degrees and freezer well let say the freezer not really that great.
If someone has completed this project need some guidance
and pic would be helpful.
Henry
Henry
Houston TX
Scamp 2017 16ft FB/SD
06-17-2018, 10:26 AM
Trailer: 2000 16ft Scamp
fan
I have the same fan, it helps a ton and with the D cells it does run for a month. No wiring to worry about.
John
The earth without art is just eh....
06-17-2018, 10:51 AM
Newbie question coming your way...
Do you put this battery operated fan inside the refig itself?
06-17-2018, 11:17 AM
Trailer: Scamp 16' Deluxe side bath
fan
I use the same camco fan. Works great and batteries last a long time. The other fan mentioned here not so good. Went through 3 of those.
06-17-2018, 12:02 PM
Trailer: Winnebago
Curious, I am not a fiberglas guy - one of the things I noticed was the frig has 2 vents on it's back side - one low one high.
Since the heat exchange going on back there is essential, has anyone looked at ways to improve air flow?
Maybe a small exhaust fan (high) and maybe an intake (low)?
06-17-2018, 12:04 PM
Originally Posted by DanoFL
Curious, I am not a fiberglas guy - one of the things I noticed was the frig has 2 vents on it's back side - one low onehigh.
One intake, one outgo. Sometimes the top vent is on the roof, sometimes its on the side . For some reason, the top vent is ALWAYS on the side in a pop-up tent camper .
BTW, I went cross country in a Winni when I was 20... but now its a fiberglass egg for me
06-17-2018, 12:26 PM
Trailer: ,Retro by Riverside RV
I use 2 of the Camco battery operated and last trip of 4.5 weeks still blowing and keeping the fridge 33_40f and freezer -3.
Mark
06-17-2018, 12:37 PM
Trailer: Roamer 1
Smith Valley, Nevada
Use of fans in the exterior fridge vents is not uncommon and it has nothing to do with being fiberglass or a sticky. The fans are a very good idea in hot weather.
I've had at least two units with factory installed fans and my Oliver has a switch on the panel for that fan.
06-17-2018, 01:17 PM
Yes they have, and there has been A LOT written on the subject on the Internet over the years. One at a time, this thread is bringing up up all those suggestions again.
I’ll try to quickly outline them, but its from memory so I might miss something. If you need more detail, its available.
Absorption Fridge tips
Operation:- Level the fridge.
- Park so the fridge side is not in the sun, or add a shade.
- Open door as little as possible and for a short a time as possible (know where things are and dont go hunting).
- Pre-cool the fridge and food that goes in it.
- Pack the fridge roughly 50-75 percent full, and in a way that allows air to circulate around the food and the fins.
- Propane is sometimes more effective than 120 volts. 12 volts is usually only to maintain the temp with the door closed while traveling and tow vehicle supplying power.
- Have pressure checks done annual (the fridge uses a very small flame and is sensitive to improper regulator setting).
Modifications:
- Add insulation to the box part of the fridge.
- Use a small fan inside to move the air over the food and cooling fins. (Usually battery operated).
- Use a fan or two to move over air over the evaporator and condenser, from the intake to the exhaust vents.
06-17-2018, 01:23 PM
There is another idea.. and I will be testing it in July...
https://www.amazon.com/gp/product/B01J0WQ48A
Runs off 12 volts or 120.. should work well when I am mostly on the road. For longer stays I will fire up the big fridge in the camper.
06-17-2018, 01:49 PM
The permanent fix for fridge cooling is a 12 volt-powered thermostatically controlled exhaust fan mounted near the top vent to draw air through the system when the temperature rises above about 90F. If you use your fridge 24/7, an inspection will likely show it is heating up so much that the nearby woodwork is starting to burn.
It is criminal, that trailer manufacturers don't fix known problems like this that are clearly spelled out in the appliance installation manual. They think the average owner is too brain-dead to notice until it is too late for a warranty claim. Travesties like lack of fridge cooling make you wonder what else they have cut corners on? Until owners raise enough cain, this sort of thing will continue. Caveat emptor.
Propane refrigerators, on the whole, are very powerful. Mine generates TWO containers of ice cubes starting from OAT on a hot day in SIX hours without any foolishness of "pre-cooling". But my exhaust fan is running most of the time the fridge is on.
06-23-2018, 04:37 PM
Trailer: Phoenix
I had two 80mm computer box fans blowing out at the top when we had an adsorption fridge. No longer needed with a compressor fridge. One was on a 90°f fixed t-stat switch, the other on an adjustable that ended up being set at about 90°f. They were annoyingly loud, but they did improve the fridge's performance..
Cross-Threaded is tighter than Lock-tite
06-24-2018, 09:08 AM
Trailer: Shopping for new RV
There are two possible “Fans” for use in RV refrigerators. One very basic battery operated fan placed on a shelf inside your refrigerator. These cheap devices are available in RV stores and through Amazon.
If you go on Amazon and search for these fans for RV refrigerators you will find not only these but higher quality RV factory type 12 Volt DC hard wired fan units (often called muffin fans). These units are designed to cool the operating systems of refrigerators and also are found in some computers. Much information on these two types can be found on the Amazon website.
I purchase most if not all of my RV supplied through Amazon...excellent selection and prices...fast delivery.
Happy Camping
