Fan install for Trillium - Fiberglass RV
Old 02-19-2013, 11:16 PM   #1
Trailer: Trillium 1300
Hey Trillium Owners...got a question. I wanted to install one of those fantastic fans in my 1975 Trillium 1300. The RV dealer said it could not be done...any suggestions.
Shelley Brinacombe is offline   Reply With Quote
Old 02-19-2013, 11:37 PM   #2
The dealer is correct in that you cant just take the fantastic fan out of the box and put it into your trailer. If you do it will hang down low into the trailer. Part of the challenge is that a Fantastic Fan is designed to go into a traditional stick trailer roof. A stick trailer has a much thicker roof compared with your fiberglass trillium. As a result, you need to come up with some sort of spacer to lift the vent up and fill in the gap.
We recently had a really good discussion about installing the fantastic fan in a boler. You will probably find a lot of that discussion applies to you. There were a couple of very good solutions to this problem documented in that discussion, complete with photos.
Check out the Boler discussion here:
Fantastic Fan Install
glamourpets is offline   Reply With Quote
Old 02-20-2013, 08:07 AM   #3
David Tilston's Avatar
Your 1300 has a 9" vent opening. That is probably what the dealer has an issue with. Since the Fantastic fan requires a 14" opening, it will be necessary to cut a larger opening. This is intimidating for some.
Measure twice, cut once.
Old 02-20-2013, 08:29 AM   #4
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Didn't someone recently post a source for a 9" vent fan? Not a Fantastic fan, but maybe better than none.
Old 02-20-2013, 09:08 AM   #5
BrandonC showed me some pictures of his install. He used a large computer fan. I don't think he is done yet. Hopefully he updates this thread wheh he is finished.
Trillium Roof Vent Weather strip/seal source?
Old 02-20-2013, 05:51 PM   #6
Trailer: 1979 Scamp 16- side bath
Virginia
I've found the fiberglass is ally easy to cut. Many types of tools will do the job just fine. For a slow and calculated/accurate cut I've found the oscillating tools work very well- I have a Drexel multimax. Just make sure to carefully mark out the new cuts, I prefer blue/green painters tape as it give you a nice defined edge compared to a pencil line, plus if protects the surrounding fiberglass should your cutting edge slip a little. I run a shop vac directly under the path of the falling fiberglass dust, and wear proper clothing and lung/eye protection.
Check out this Maxxair fan I found one for significantly cheaper than in this link.....
http://www.amazon.com/Maxxair-00-051...ds=maxxair+fan
Mine only drops below the interior of the ceiling by about 3/4" and I did not have to build up a structure above the roofline. I only had to create a thin 1/2" spacer for the interior perimeter of the mounting flange. I'm super happy with the fan so far, it can stay open in the rain with its integrated vent/cover. It has something like 10 speed settings or so.
Ryan P R is offline   Reply With Quote
trillium
Fantastic Fan Install glamourpets Modifications, Alterations and Updates 68 02-04-2013 11:59 PM
Fantastic Fan install Gordon Kinslow Problem Solving | Owners Helping Owners 6 04-01-2011 09:37 PM
Fantastic fan install John Clayton Problem Solving | Owners Helping Owners 6 04-02-2010 09:46 PM
How *not* to install a fan vent Amy M Problem Solving | Owners Helping Owners 7 02-22-2010 07:32 PM
Fantastic fan flange install Pat C Problem Solving | Owners Helping Owners 8 07-05-2009 09:43 AM
