Fan removal - Fiberglass RV
Old 04-06-2014, 02:18 PM   #1
Tilly's Avatar
Trailer: 1976 Boler 1300
Manitoba
Fan removal
Hi folks
Started the replacement of our old fan. I expected to drill out the rivets from the interior, but there are only four accessible. The remainder exterior rivets seem "blind" - so only accessible from the roof.
How do I drill these out if I can't retrieve them? Won't they be jammed in the holes I need to fit the new fan?
Merci
Tilly is offline   Reply With Quote
Old 04-06-2014, 02:22 PM   #2
Tilly's Avatar
Manitoba
And the photo...
[attach]
Code:
69583
[/attach]
Old 04-08-2014, 12:47 PM   #3
I just drilled mine out from the roof using a ladder.
Would you mind telling me what size you fan is? The hole left behind from my old vent is 9"x9" but the fantastic vent I bought is 14"x14" - this was the only size I could find from fantastic fan. I'm just wondering if there are other sizes out there before I start cutting the roof!!
ddicks is offline   Reply With Quote
Old 04-08-2014, 01:00 PM   #4
Just drill them out from the roof. Your going to have to set it up to get at the roof anyways if you are planning on installing a new vent.
Old 04-08-2014, 03:27 PM   #5
David Tilston's Avatar
Many older trailer have a 9" vent. All of my Trillium 1300's do. I have never seen a 9" vent with a fan, other then ones made by members of this site. 14" fan vents are all you will find.
The problem with just cutting a new hole is that you loose the lip around the vent. This causes the fan to hang too low. A good idea is to add a frame on the outside of the trailer that will hold the fan higher, so you don't bump your head.
DYNAFORM Sq Tube,ISOFR,Gry,1/8 T x1 In OD Sq,5 Ft - Fiberglass Square Tube Stock - 4ATN8|870860 - Grainger Industrial Supply
http://www.fiberglassrv.com/forums/f...tml#post360131
Also, Fantastic makes fans that don't protrude as far into the trailer:
http://www.fiberglassrv.com/forums/f...tml#post359739
Old 04-08-2014, 03:55 PM   #6
David B.'s Avatar
Tilly, you could just try modifying what you already have with either 6" pancake fan or fans or another aftermarket like endless breeze or O2 Cool fan attached to what you already have.
Just something that struck me as funny (warped I guess) was the statement
ddicks I just drilled mine out from the roof using a ladder.
I would have used a drill bit.
Dave & Paula
Old 04-13-2014, 06:11 AM   #7
Tilly's Avatar
Manitoba
Oh dear. Thx everyone for the replies. Managed to get things done - drilled out no prob. But got spooked I had mistaken the size of the old vent! So after I checked the forum this morning i put my boots on right away to go check the hole in the boler roof, measuring tape in hand....
All good. Hole dug, butyl tape at the ready...hope to put it in place soon.
Not sure if the profile will be too low, so will keep some of your ideas in mind. Thx!
Old 04-13-2014, 06:12 AM   #8
Tilly's Avatar
Manitoba
Vent 14 x 14 - same as hole.
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Fan-tastic Fan Seller - Best Price I Found barryra General Chat 1 07-11-2011 04:51 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Front Dinette Construction/Couch Removal Question Karen B. Problem Solving | Owners Helping Owners 2 06-13-2009 09:03 PM
Fan-tastic fan Ken&Chris Problem Solving | Owners Helping Owners 13 04-11-2006 07:15 PM
