Fan-tastic vent speed/noise reduction - Fiberglass RV
Old 05-21-2014, 03:02 PM   #1
John Linck's Avatar
Madison, Wisconsin
I wanted to slow the speed of my Fan-tastic fan and emailed the fan folks asking how to. They replied with the message below and the attached diagram. Sorry if this is old news. Worked for me. I may add a switch to bypass the resistor on hot days. We will try it this way for awhile and see how it does. So far very nicely.
John Linck
John,
Thank you for contacting Fan-Tastic Vent. Please find the attached instructions to slow fan motor. You’ll find resistors at Radio Shack or similar retailers.
Best regards,
Jerry Watchorn
Technical CSR
Fan-Tastic Vent
Atwood Mobile Products, LLC
John Linck is offline   Reply With Quote
Old 05-21-2014, 03:06 PM   #2
cpaharley2008's Avatar
Yes, you are supposed to install the in line resistor so that the fan cools it. I got tired of doing this, after 4 different times I switched to MaxxFan.
Jim
Never in doubt, often wrong
Old 05-21-2014, 03:21 PM   #3
Trailer: Casita 17 ft DLX SD
This reminds me of the old style light dimmers (Pre solid state) The resistor solved one problem, dimming the lights but created another problem ,getting rid of the heat produced by the resistor . Plus it did nothing for energy conservation
Old 05-21-2014, 03:28 PM   #4
David Tilston's Avatar
I am thinking of putting something like this in my Fantastic fan. At $3.83, it probably costs less then that 10W resistor from Radio Shack.
Hi Q Pulse Width PWM DC Motor Speed Regulator Controller Switch 6V 12V 24V New | eBay
Hi-Q Pulse Width PWM DC Motor Speed Regulator Controller Switch 6V 12V 24V New
Features:
Brand new and high quality.
Input supply voltage: DC 6V-28V.
The maximum output power: 90W(Voltage * Current should be smaller than 90).
The maximum continuous output current : 3A(If current is larger than 3A, enhancement of heat dissipation is required.).
PWM frequency: 21kHz.
Duty Cycle adjustable: 5%-100%.
Size:5cm x 2.8cm .
Old 05-21-2014, 07:19 PM   #5
John Linck's Avatar
Madison, Wisconsin
Jim,
I asked Scamp if the MaxxFan was an option. Sadly no. In hindsight I should have installed one myself.
David,
I like your suggestion. Let us know how pulse width control works. Sounds like the best solution.
Thanks to all, john
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
Old 05-21-2014, 07:25 PM   #6
John Linck's Avatar
Madison, Wisconsin
David,
I just ordered your controller suggestion. I have never heard of an adjustable duty cycle, maybe that's just translation meaning variable speed or my ignorance. Anyway it looks good, but if not I have squandered 4 dollars much more recklessly at times. One less beer in Egg Harbor next month.
Cheers, john
Old 05-21-2014, 07:41 PM   #7
Adjustable duty cycle = variable on vs. off time, or pulse width modulation. A standard DC speed control. Since the switching frequency is 21 kHz, it should be basically silent.
If you have installed a reversing switch, it may be a good idea to put it down stream of the speed control, which seems to have a polarity to it.
Old 05-23-2014, 01:10 AM   #8
The motor speed control mentioned is rated at 3 Amps. Seems to me that a large fan might use more that 3 Amps.
Frank F
frankcfx is offline   Reply With Quote
Old 05-23-2014, 04:02 AM   #9
Raz
Raz's Avatar
Vermont
The big benefit to a pulse width modulated control is it allows a wide range of control. A properly designed controller should allow you to slow the motor to the point where you can see the shaft rotate. The controller provides full voltage at shortened intervals. The resistor reduces the voltage to the motor. Too large a resistor and the motor stalls. The down side to the controller is where to put it. It will need some ventilation. Raz
Old 05-23-2014, 08:21 AM   #10
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
Our range hood exhaust fan was either screaming, or nothing. Very annoying. I installed a rheostat in series and we are both very happy, it works well. The amount of time that we use the range hood is short, so I am not too worried about the wasted power. I do not have any commercial info on the rheostat, it is something I've had in my collection of "useful" stuff, probably for decades. I am a pack rat, and it has paid off many times. Just need to remind my DW every time I save big bucks.
Old 05-23-2014, 08:33 AM   #11
Frank F
The fan is rated at 3 amps.
Old 05-26-2014, 06:01 PM   #12
Well, I bought a Maxxair fan off of kijiji today. It is the 5100 model, but an older version. It has only three speeds, and a dial thermostat that has no units on it. It is reversible though. Not a screaming deal at $170, but it was brand new in the box.
It is rated at 4.4 Amps. So to add better speed control, I purchased this unit today.
6V 12 24V 10A Pulse Width Modulator PWM DC Motor Speed Control Switch Controller | eBay
Specification:
Model: CCM6C
Input voltage: 6V/12V /24V DC
Control Power: 24V, within 200W; 12V , within 200W; 6V , within 60W
Current: Sustained current maximum 20A, suggest use within 10A
PWM Duty Cycle:5% -100%
PWM Frequency:21khz
Material: Plastic, metal
Size (L*W*H):6 x 5 x 2.7cm/2.36"x1.96"x1.06"(approx)
At $5.06, it is not much more expensive then the 3A model. It is also larger, so it may not fit, but it should be interesting. Otherwise the specs are almost the same.
Old 10-25-2017, 06:49 AM   #13
John Linck's Avatar
Madison, Wisconsin
I tried the pwm control. Wow! Very nice and working great after 3 years.
John
Pic from Michigan's Upper Pennisula during fall color.
Old 10-25-2017, 08:08 AM   #14
complicated
I look at those transittors, diodes, resistors and the big heat sink makes me cringe. So many things to go out or wrong!
guess this is the new age of anything?
bob
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Fan-tastic install question: caulk, butyl, or other...? spartacus Care and Feeding of Molded Fiberglass Trailers 5 07-18-2013 05:01 AM
Fan-tastic Fan Seller - Best Price I Found barryra General Chat 1 07-11-2011 04:51 PM
Fan-Tastic Vent Speed Mod Patrick M. Modifications, Alterations and Updates 7 03-05-2008 11:40 PM
Fan-tastic fan Ken&Chris Problem Solving | Owners Helping Owners 13 04-11-2006 07:15 PM
» Trailer Showcase
Bigfoot
K Ross
BIGFOOT
OKE
