Fantastic Fan Install in Bigfoot - Page 3 - Fiberglass RV
Old 02-26-2016, 04:49 PM   #29
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
Put some lap sealant on the roof. Hopefully this does the trick.
ID:	92887 Click image for larger version
Wiring will happen in a week or so...
Next up for re-sealing:
Old 03-06-2016, 06:08 PM   #30
ZachO's Avatar
Montana
Well we had some pretty serious rain over the last week, and I don't see any signs of leaking around the new vent. Not sure if it would necessarily be so obvious as a drip from right around the vent, or if it would just make it's way into different areas of the ceiling and eventually stain the ceiling...but nothing obvious going on.
I just got two new vent caps, and am considering replacing that small bathroom vent in the last photo. Once the rain clears up I'll get back on it.
Old 03-06-2016, 06:49 PM   #31
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
What size is the opening on that bathroom vent? Mine had a standard 14x14 opening but with a passive vent. I ran some new wiring and replaced it with a powered exhaust vent..
Big improvement in the Summer.
Walt
Old 03-07-2016, 07:03 AM   #32
ZachO's Avatar
Montana
Hey Walt. It's 9x9. Sounds like a lot people cut the hole bigger to allow for a standard size, and that would mean I could add a fan. I don't know...Probably the right thing to do but I might just stick with the 9x9. Not sure.
I need to stop spending money on this thing for a little while, but I also want to do things "right". The previous owner said that this vent leaks a little in major downpours. So I want replace it, because looking at it, I think it's more likely that it's leaking because of the cracked corner of the lid than because of needing a resealing. So I don't think that resealing it would be any kind of "bandaid" fix. I think the only way to stop the leak is replacing it.
But another $150 or so on a powered fan vent, plus taking the sawsall to my roof, just doesn't sound great right now...
We'll see!
Old 03-07-2016, 07:23 AM   #33
WaltP's Avatar
SW Virginia
Zach
A cabin exhaust fan like the Fantastic or MaxxAir is way overkill for the bathroom. Take a look at
Vortex Replacement Vent Fan Upgrade - Heng's Industries 90043-CR - Vents - Camping World
or maybe even better,
Heng's 71112-C2G1 Roof Vent, Powered, Plastic, White 12vdc
Walt
Old 03-07-2016, 10:04 AM   #34
ZachO's Avatar
Montana
Ah, thanks. Yeah a little more affordable. Looks like either way I'd be cutting a bigger hole. First one I'd still need to buy a vent plus the fan.
Second link is probably the best option...
Old 03-07-2016, 11:16 AM   #35
WaltP's Avatar
SW Virginia
Agreed.
bigfoot
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 04:25 PM
Fantastic fan flange install Pat C Problem Solving | Owners Helping Owners 8 07-05-2009 09:43 AM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Install - switch to change air flow? Kurt in BC Problem Solving | Owners Helping Owners 29 11-11-2007 04:58 PM
Fantastic Fan install questions TonyL Problem Solving | Owners Helping Owners 18 02-28-2006 06:59 AM
