Fantastic Fan Install On Curved Burro Roof - Fiberglass RV
Old 10-08-2015, 10:05 PM   #1
Trailer: Burro
Hello all,
I just purchased a 1984 ten foot Burro and am making some upgrades. The first of which is getting a fantastic fan in there. It has the standard 14x14 hole. I've heard of people having issues with the curved roofs. The curve is slight but does this mean I have to build some sort of curved shim to get the fan to seat properly? I did here that the plastic mounting frame will bend some? Will it bend enough to meet the curve of the Burro's roof? Will I be in danger of cracking or distorting the fan housing? If anyone has had any luck with this please let me know. I would prefer not to fabricate a custom shim. Would love to hear your experiences!
Thanks,
Tom
Tommy Gun is offline   Reply With Quote
Old 10-08-2015, 11:29 PM   #2
David B.'s Avatar
I had replace our 13' Scamps' roof vent with fan, with a Fantastic Fan (wish I had went with a MaxxAir Fan), and it had a "shim platform" to mount it to. I would suggest making a template out of styrofoam, or modeling clay, then out of wood or fiberglass right over the clay.
Keep us posted.................and send pictures.
Dave & Paula
Old 10-09-2015, 12:04 AM   #3
Trailer: Burro
why do you prefer max air over fantastic? would it fit my curve better? I was about to pick up a fantastic fan 1250 but it did not say anything about a curved shim on the box ?
Sent from my iPhone using Tapatalk
Old 10-09-2015, 09:17 AM   #4
SUNnLUNA's Avatar
Trailer: 1982 Burro
I replaced my 1982 Burro's vent with a Fantastic Fan. We had to build a wood shim for it to fit properly. Looks great and well worth it! Good luck!
SUNnLUNA is offline   Reply With Quote
Old 10-09-2015, 10:15 AM   #5
David Tilston's Avatar
I suspect the difference has nothing to do with mounting issues. The Maxxfan can be operated in the rain, where the Fantastic fan can't.
Old 10-09-2015, 10:29 AM   #6
David B.'s Avatar
The MaxxFan has 10 speeds forward and 10 reverse... runs much slower and draws less amps at lower speeds, is quieter at lower speeds also. The MaxxFan can be left open during rain, has two lid supports instead of only one, so the lid is much more stable in the wind. The cost for either basic model was within $25.00 of each other, depending on where you purchase it. The base does not lend itself to mount to a curved surface any better than the Fantastic fan does.
Dave and Paula
Old 10-09-2015, 10:51 AM   #7
It should be noted that paying more then $10 for speed control is not necessary:
http://www.fiberglassrv.com/forums/f...tor-64815.html
Old 10-10-2015, 06:55 PM   #8
Trailer: Burro
thank you everyone I'll let you know how it goes
burro
Maxx Fan Installation on curved roof scf Modifications, Alterations and Updates 3 03-08-2015 03:24 PM
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 04:25 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Install - switch to change air flow? Kurt in BC Problem Solving | Owners Helping Owners 29 11-11-2007 05:58 PM
Fantastic Fan install questions TonyL Problem Solving | Owners Helping Owners 18 02-28-2006 07:59 AM
