Fantastic Fan question - Fiberglass RV
Old 05-25-2013, 11:36 PM   #1
Trailer: 1977 Scamp 13'
Iowa
OK so I ordered a Fantastic Fan from AdventureRV. I wanted a basic model 8000 Create-a-breeze. What I received was unexpected. A model 8000RBT, so this unit has a thermostat and the reverse switch. Unit has a mfg date of 5/13 .. really new.
It appears the unit is a "High Profile" unit, the bottom part (goes in trailer) is only about an inch. But there are only 16 screw holes in this. I thought there were supposed to be 28 on high profile units. Should I be concerned? or are they simply being made this way now.
Joe M is offline   Reply With Quote
Old 05-25-2013, 11:53 PM   #2
Trailer: '77 Scamp
I can say my low profile has 16 screws. The less the better I think. Less holes to drill and areas for possible leakage. If you like everything else about it, shouldn't really matter. Sounds like you got more than you were expecting so that's great. These fans are great. I have the same Scamp as you do, and the new fan was a tremendous addition to the comfort level.
Otters is offline   Reply With Quote
Old 05-26-2013, 07:27 AM   #3
GMike A's Avatar
I know you have read it a hundred times but just in case NO silicone only butyl tape. You will find tons of threads on it.
Take some before and after progress pixs if you would.
thanks
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 04:25 PM
Fantastic Fan Thermostat Switch Question Bruce H Care and Feeding of Molded Fiberglass Trailers 4 09-09-2010 10:01 AM
Fantastic Fan question Sandra Lair Problem Solving | Owners Helping Owners 5 07-22-2008 10:07 PM
Fantastic Fan question Sandra Lair Modifications, Alterations and Updates 17 08-08-2006 06:33 AM
Question for Fantastic Fan Owners Doug Hounshell Care and Feeding of Molded Fiberglass Trailers 10 03-02-2006 04:25 PM
