Fantastic Vent upgrades.... - Fiberglass RV
Old 01-12-2012, 02:14 PM   #1
cpaharley2008's Avatar
For those who have Fantastic Vent's installed in their Egg's and wished for improvement, there is some hope. They now offer an insulated double pane replacement roof vent which will take care of any condensation issues dripping from the vents. In addition they have a reverse kit available which includes the thermostat with 3 speeds and the new pop 'n' lock screen. Also they will send you a resistor kit to slow down your fan speed. Atwood has purchased Fantastic Vent and is expanding their products. But they will still honor Fantastic Vent's lifetime warranty. Once the upgrades arrive, I'll post install pictures, but should be, as in the past, plug 'n' play updates. The costs were $55 for the insulated vent dome, $45 for the reverse feature and $11 for the speed reducing kit.
Old 01-12-2012, 06:43 PM   #2
FanTastic!
Old 01-12-2012, 08:19 PM   #3
Trailer: 1978 Trillium 4500
Very timely information! I have a FF sitting in a box, awaiting installation. Should be asking for any/all of these things now, prior to installation?
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 01-12-2012, 11:46 PM   #4
David Tilston's Avatar
The folks at Woodies RV offered me a controls upgrade for my model 8000, (bottom of the line, I like the white dome) Fantastic fan. It included the power opening feature, and all the bells and whistles. They wanted about $350 for it. I declined. I was thinking of adding a polarity reversing switch to it, but for $45, with a thermostat, I'm in!
How do I order?
Old 01-13-2012, 03:58 AM   #5
Contact FV and they will put you in contact with a local factory rep. Mine was in Florida who then contacts the factory and has it drop shipped direct to you.
Old 01-13-2012, 05:08 AM   #6
jen b's Avatar
Trailer: 1980 13 ft. burro
So, what specifically has been the problem with these vents? I was going to replace the noisy one in the burro with one of these.
jen b is offline   Reply With Quote
Old 01-13-2012, 06:28 AM   #7
There is no problem with them, they are fantastic, to quote Darwin above. You have 2-3 choices these days when you replace your vents, Fantastic and Northern Breeze are 2 that I recall. Each one has it's advantages and each one has "extras". Do you want an automatic closing vent, do you want a manual only or thermostat control, do you want in/out exhaust/fan options. Sort of like options on a car, some people want different ones. So you customize it the way you want it.
Old 01-13-2012, 09:51 AM   #8
I love my fan! The bottom of the line fan I purchased is currently selling for $175 at Woodies RV in Calgary. They work great. Three speeds, but that is it, not even reverse. I purchased this model because I wanted a white dome. The top of the line has a remote, power open, rain detector, thermostat, and I am sure other features I am missing.
I did not see any reason for reverse. After thinking about it I realized that instead of a range hood, if I ran the fan blowing in and open the window behind the stove, then this would serve the same purpose. A thermostat would be nice too. The lower speed option also makes sense. The lowest speed is still quite fast. If all you are doing is trying to keep the air fresh while you sleep, less noise would probably be appreciated.
If you purchase one. I understand that they can be purchased with a kit for the thin walls of a fibreglass trailer. The one I bought was set up for walls up to 2" thick. It works, but if I knew that they have something suited for a thinner wall, then I would have gone for that.
Old 01-13-2012, 10:37 AM   #9
My Fantastic Fan is at the top of the list of the best things I have ever added to my trailer. When I first got my trailer I carried a small portable AC that went into the back window of the trailer that I used when in hot areas. I have not carried it or needed it since putting in the Fantastic Fan - it was all I needed even while camping in July in Montana and Wyoming where the temps where in the 90's. Mind you I wasn't in the trailer during the day but it worked well at cooling the trailer down fast at night making for a comfortable sleep.
I purchased mine about 3 years ago at Camping World in Portland when it was on sale for about $125 - its the 4000R model - three speed with reverse. The one down side to it, if you can really call it a down side is that on the lowest setting it is still pretty strong - I might look at adding the resister kit. If I was to purchase a new fan the next time I would get the rain sensor one so I dont need to get up in the middle of the night and close the vent if it starts to rain. :-) I know you can put the covers on them but I need to watch the height of my trailer due to clearance issues for storage and the fact I take the trailer on the ferry and adding another couple of inches to the height will put me in a new class of "over height" in the fares - costing a lot more for the ferry ride.
Fantastic Fan has had *amazing* customer service. I sure hope that does not change with the change in ownership.
Old 01-13-2012, 02:13 PM   #10
My van is a bit higher then my Trillium. How high is "over height"?
Old 01-13-2012, 02:35 PM   #11
THe Washington state ferries overheight charge is:
Vehicle U14' Over 7'6 in. Height Surcharge $11.25
My trillium is almost exactly 7'6 at the top of the existing roof vent
SRC: http://www.wsdot.wa.gov/ferries/fare...arrivingterm=7
Cheers
--Fred and Natalie
Old 01-13-2012, 02:43 PM   #12
Guess I will be paying the surcharge.
Old 01-13-2012, 03:04 PM   #13
Maybe not. It may depend on how much over it is! Have found that Washington State ferry staff are very generous when it comes to measuring and have let me go without charging it, even though they know its over Dont want to push my luck on that front by increasing the height of the trailer any higher than it is.
BC Ferries on the other hand has never been nice about giving some slack with over height charges. The good news is though that last year they stopped charging for over height which if I recall correctly was 7' and they charged so much a foot or portion of a foot over .... now they just hammer you $5.35 for every foot over 20' of your combined tow and trailer length.
Old 01-13-2012, 03:08 PM   #14
if you are within a couple of inches in a passenger van I'm sure they won't even think about the overheight charge.
Cheers
--Fred and Natalie
Fantastic Vent upgrade cpaharley2008 Modifications, Alterations and Updates 5 06-18-2011 12:17 PM
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
Fantastic Vent for sale Craig Broughton Classified Archives 0 04-01-2009 02:46 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Installing Fantastic Vent in a Bigfoot Bonnie B. Problem Solving | Owners Helping Owners 4 07-10-2006 09:22 PM
