Fiberglass Repair Suggestions - Fiberglass RV
Old 05-24-2015, 02:31 PM   #1
Trailer: In the market
Hi guys, I have a question about a hinge that is breaking out from the fiberglass from fatigue and age. It looks like the metal hinge is just molded into the fiberglass and now it needs some more support.
I was thinking about just filling it up with epoxy (between the existing fiberglass and the metal hinge), but thought someone might recommend to strengthen it more by adding some fiberglass in there or maybe its a bad idea, but I dont know. Im new to fiberglass.
bhollehday is offline   Reply With Quote
Old 05-24-2015, 03:57 PM   #2
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
I , like others would be happy to offer suggestions but I/we need a little more input.
The picture you posted is great but more angles are necessary in order to
get a better idea what your up against.
Fred
FRED SMAILES is offline   Reply With Quote
Old 05-24-2015, 04:17 PM   #3
Fred
Hope this helps.
Its solid enough to hold the weight, but its just a little fragile and just needs some extra support. Im not going to add brackets or bolts, I think that an epoxy/glue/fiberglass will do the job just fine, just need some incite on what would be the strongest method.
Old 05-25-2015, 01:49 PM   #4
Trailer: 1985 BigFoot G
Mississippi
Originally Posted by bhollehday View Post
Hope this helps.
Where is this? Is it under the Bigfoot? What does that hold up or does it hold up anything?
Gardnpondr is offline   Reply With Quote
Old 05-25-2015, 01:55 PM   #5
Its a bed cover for a truck so its just hinging its own weight up. It holds its wight just fine but if you yank on it you can hear cracking fiberglass and see some movement from the hinge or foot. So I planned on either just filling the gap with epoxy, or maybe adding some fiberglass in there as well.
Old 05-25-2015, 02:06 PM   #6
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Bryan, how about a couple pics from a bit of a distance, in the closed and open position. I think I know what you're asking but can't get a reference with the close up shots.
Old 05-25-2015, 03:09 PM   #7
Roger C H's Avatar
Smile Car body repair or boat yards
Both work with fiberglass.
Old 05-25-2015, 04:12 PM   #8
here you go
Old 05-25-2015, 05:50 PM   #9
Well, it doesn't look like a hinge to me but an offset clip to hold the front down. Am I right? If that is the case and you have clearance with seal and top of the bottom box you should be able to incase the flat part with some fiberglass cloth and mat. I would think one layer should be fine.
Old 05-25-2015, 07:00 PM   #10
its, what i call a hinge, as it gives the front of the bed cover a piviting point to swing up on when you lift the back of the bed cover up. I dont completely understand where your talking about fiberglassing. Are you saying just wrap a sheet around the hinge and resin over it and between?
Old 05-25-2015, 11:08 PM   #11
With no pic of the mating unit it sounds and looks like the basic reason for this tab is to hold the lid down for travel. Never seen a lid like that before. BTW, is the other one still holding OK? I can't bring it up close enough to see it. Looks like the tab should sit flat against the lid normally. Roughing up the glass on each side of the larger flat plate a few inches and glassing over that section should tighten it up. If it was mine, I would put two 1/4" SS bolts/nuts and butyl tape on each tab and be done with it. Way quicker, secure and cheaper than glassing it over.
Old 05-25-2015, 11:59 PM   #12
Kootenay's of BC
Sorry forgot about this post.
You need to understand how to use fiberglass to effect repair.
You tube can help you there.
What I would do is remove the hinge and grind a little material off from behind the hinge and in both directions. Course sandpaper and elbow grease works too,,,, Apply a piece of fiber cloth that is saturated with activated resin to the area and place the hinge in it's original location over the glass., use a spring clamp or other device to apply firm but not heavy pressure till set. I would probably rough up the hinge face and surrounding area with course sandpaper and apply a second layer of glass.
Hope this helps.
Fred
Any suggestions on how to repair? Rideadeuce Modifications, Alterations and Updates 12 12-03-2012 09:57 AM
"How To:" fiberglass repair video Mary Lynn K. Care and Feeding of Molded Fiberglass Trailers 3 06-20-2009 06:15 PM
unusual Fiberglass repair Perry Mac Donald Problem Solving | Owners Helping Owners 7 03-21-2009 10:37 AM
Fiberglass Repair & Clear Coating mariemmoore Care and Feeding of Molded Fiberglass Trailers 15 11-04-2008 03:17 AM
Fiberglass repair Questions Kenny H Problem Solving | Owners Helping Owners 9 09-04-2008 10:20 AM
