10-12-2009, 02:42 PM
#61
Sleek!
The taillight cups look great. I read back in this thread, so I understand that you glassed them in without the usual riveted rims - can you tell how you went about that?
Did you glass them in from inside and then grind the rims off? Take them off and then..
Also, just curious: Is the belly band going back on? Or are you going "sleek" in that area too?
Thanks,
Raya
10-12-2009, 06:36 PM
#62
Trailer: 72 Boler American
I cut the flanges off the light cups and clamped them in place. I learned fiberglassing as I went and this was one of the most pain in the butt things I did.....but I wanted the look....and I'm pleased. The belly band is gonna go back on. I like the fact that it sticks out at the widest point of the body and acts like a buffer so the body won't get scratched......
10-12-2009, 06:41 PM
#63
Thanks, Scott!
I like the belly band on the Boler/clones too. I like the "ring of Saturn" thing it has going (although it does tend to collect dirt and whatnot on the top flange). They look great polished up, I think
Your taillights look great! I had thought if I ever painted that I would drill out the rivets, fill the holes, and glass the lights in, but I hadn't thought about eliminating the flange for a smoother look, so that intrigued me.
Raya
#64
Nice matching with your towing vehicle. BTW what is the towing capacity of the Scion?
Can't wait to see more pics.
The Scion(according to the manual) has NO towing capacity...... However, the engine is larger than the old style "boxy" model and in my opinion is plenty powerful. If I hit any serious hills or mountains, I'll be taking it easy for sure.......
10-12-2009, 10:33 PM
#65
It's not just a matter of engine size, but wheel base, too. A trailer is much more likely to do the steering for you when you have a short wheel base or not enough weight over the front wheels to counteract the lever-action of the trailer as it tilts forward and downward on the hitch when you brake or the trailer bounces.
10-13-2009, 01:51 PM
#66
Trailer: Boler 1984
When we repainted our Boler, I had the belly band off as well. The flange measured any where's from 5/8" to 1 1/2" so I marked it with a spacer and a pencil and ground it back to a common width. When I reinstalled the band I had to cut it shorter by about 1 1/2" because of the smaller sizing. I then polished the metal band with aluminum mag and wheel cleaner. Sure made a difference...... at least in my minds eye.
Thanks for the pictures. Looks like a very nice job. You're going to get a lot of looks when you go camping.
Jim
10-15-2009, 08:33 AM
#67
I love the XB & Boler look....
wish my 72 looked that good!!
10-15-2009, 08:39 AM
#68
Sorry - forgot most recent photos of mine
Still need some shots of completed outside - - and inside with my curtains and new front cushions....
10-17-2009, 04:26 PM
#69
Cut the holes in the benches for access. I ordered 4 interior window trim rings which had the correct profile
to rest panels in. The cover panels are 1/2 inch StarBoard. Oh, and, the LEDs went on today!
10-17-2009, 04:55 PM
#70
Trailer: 1977 Boler 1300
Brian, One sugestion:
Take a die grinder and cut the body back a little more from around the frame openings front and back. There is some different colored edge welting that you cane put on after to finish them off.
The reason being, over the years most or the frame cracks and breaks I have seen tend occur just behind the body opening. What happens is mud and water build up in there and doesn't get enough expose to air circulation. It is a spot most people don't think to hose out good after they have been on a muddy road.
You are doing a first class job on your rebuild.
04-15-2010, 05:41 PM
#71
Just checking in with my limited progress as of late. The windows are all in and I installed the door latch this evening.
I had the front and rear plexi windows put in by a local auto glazier $50.00 well spent as far as I'm concerned.
Next, I need to get a table in and a front backrest/top bunk built. Then I call the upolsterer. I'm not looking foward to
that bill.
04-15-2010, 09:10 PM
#72
Brian, I was really busy with work when you posted your tail lights, nice job. I'd like to do the same.
04-25-2010, 09:34 PM
#73
Just a few little things that have been crossed off the list......
I just had to throw up a pic of my baby on the day I started.........
04-26-2010, 11:47 PM
#74
Personalized trailer plates in NY?
Way to go!!!
04-28-2010, 03:38 PM
#75
More pics!!! I'm so excited.......It's finally (after two years) out of my garage! The new wheels went on today and it won't be fitting through
the door anymore. I sure do hope there are no leaks. I'll find out next time it rains.
04-28-2010, 03:57 PM
#76
Trailer: 16 ft U-Haul VT
Looks really sharp!
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
04-28-2010, 04:31 PM
#77
Trailer: Boler 1300 1973
Did you do anything to prevent spider web cracks to appear again before repainting ?
Boler 1300 1973
Jeep Wrangler 2dr 2012
04-28-2010, 05:58 PM
#78
A good deal of the small cracks were ground out and filled in. There are a few I missed. Oh, well.... In fact, every penetration through the hull was covered over
(water inlets, heater vent, electrical, spare tire mounts, and EVERY DAMNED rivet hole) except the windows.......This way I can start and build as if it were new.
I need to get a few things done around the house and yard, then I'll begin the interior part of this project.
04-28-2010, 11:26 PM
#79
Rather than make new rivet holes for the cabinetry, you might want to consider tabbing it in (with fiberglass). That actually adds strength over rivets (not that the rivets aren't adequate) and .... no holes!
Rivets are much faster and easier, so they are well suited to a factory setting in making an affordable product. But on your own camper, where you are not trying to build 300 of them where shaving off a little time/skill is a big deal, a little extra time and effort could make it "better than new."
Raya
04-29-2010, 05:45 AM
#80
Raya, I know you are a big fan or tabbing, and I know what you mean as far as technique generally. I am wondering if you know of videos or postings that descibes the process in detail?
