First pictures of the Aluminum floor. - Fiberglass RV
Old 07-12-2010, 07:52 PM   #1
Rick n's Avatar
Trailer: Beachcomber TM15
Aluminum floor test fit and cut, all the seams will be covered by the benches and the cabinetry
Bronco_Convertible_top_and_aluminim_foam_001.jpg   Bronco_Convertible_top_and_aluminim_foam_002.jpg
Bronco_Convertible_top_and_aluminim_foam_003.jpg   Bronco_Convertible_top_and_aluminim_foam_004.jpg
Bronco_Convertible_top_and_aluminim_foam_005.jpg   Bronco_Convertible_top_and_aluminim_foam_006.jpg
Rick n is offline   Reply With Quote
Old 07-12-2010, 07:53 PM   #2
Rick n's Avatar
The rest of the pictures
Bronco_Convertible_top_and_aluminim_foam_006.jpg   Bronco_Convertible_top_and_aluminim_foam_007.jpg
Old 07-13-2010, 08:05 AM   #3
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
Looks interesting but will it be cold? I'm just thinking of my tootsies on a 3AM bathroom jaunt!
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 07-13-2010, 08:48 AM   #4
Robert Johans's Avatar
Trailer: Nest Caravans
Interesting stuff... Is it available commercially? How's the cost? How is it cut? So many questions...
Old 07-13-2010, 01:12 PM   #5
Rick n's Avatar
I'll let you know on the cold tootsies, but I'm pretty sure it won't be anything a mat on the floor can't take care of LOL.
Old 07-13-2010, 01:33 PM   #6
Rick n's Avatar
It is available commercially but I don't know if you can buy it retail just yet.
The company that makes and sells it is called Alusion
Their website is www.alusion.com
We cut it with a cross cut blade and a Skill saw, maybe not the best method but it worked for our requirements, I'm just kind of experimenting at the moment.
I'll be using a product on the walls called Sintra, it's a sheet plastic about 1/8th inch thick or something similar.
Available at most plastics retailers.
My goal is to make this little trailer as impervious to water damage as is possible with an eye on cost.
For the walls and floor bracing I'll be using a product called Bluwood available at Loews in Canada, I don't know if it's available in the USA yet.
It's made to resist Mold and Fungus and wood ingesting insects.
Their website www.bluwoodcanada.com
In doing this rebuild I thought that I might as well try and use new and innovative products to complete the job with the goal of having a comfortable long lasting trailer as the end result.
Old 07-13-2010, 01:35 PM   #7
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
How easy will it dent?
Old 07-13-2010, 01:46 PM   #8
Rick n's Avatar
It's made up of millions of little air bubbles covered with a hard candy shell sort of like an Areo chocolate bar with an M&M coating, just walking on it I don't think it will dent and depending on it's bubble size and the number of bubbles and the thickness I believe these things all affect it.
The stuff I'm using is 1/2 inch thickness and pretty rigid, I also will be covering the top of it with a 2 part clear epoxy for shine and easy clean up ie... sweeping or moping of the floor It should also give it the appearance of ceramic flooring with out the weight or breaking problem of ceramic tile.
Old 07-14-2010, 09:19 AM   #9
Trailer: Beachcomber B15
so yeah I got some curtains sewn for mine and managed to paint a little........ sooooo jealous right now.
Looks swank. I love the epoxy, that will give it a nice finish and it should take care of some of the cold problem too (depending on the thickness?).
Can't wait to hear about the paneling install.
Michelle GB is offline   Reply With Quote
Old 07-14-2010, 04:05 PM   #10
Rick n's Avatar
Post
Don't be jealous, if anybody should be jealous it should be me LOL, you guys at least get to use your Beachcomber, the condition ours was in, well let's just say I can't believe the folks that owned it before us used it.
Old 07-17-2010, 05:33 AM   #11
Roy in TO's Avatar
Rick,
How do you think that stuff would work for stove and sink covers?
Or cupboard doors for that matter?
Old 07-17-2010, 06:11 AM   #12
Rick n's Avatar
Rick,
Actually Roy I'll be using it to make the counter top and benches using 1 by 3 Bluwood for the framing and then two part clear epoxy top coat finish for easy wipe down and clean up.
Like I said in a previous post this is a fairly new building material and all is experimental but so far it looks like it's working out pretty good and the product looks great.
Old 07-17-2010, 09:43 AM   #13
Roger C H's Avatar
Talking
I would think these would work well:
http://www.pacificpanels.com/
They are used in airplanes.
Old 07-24-2010, 08:24 PM   #14
Heath G.'s Avatar
Trailer: Compact Jr
Ohio
Hi Rick, the floor looks good. do you have an idea of the weight of the floor? also wondering about the cost. I have a compact jr I was thinking of doing a frame off on this winter and was trying to think of something other than ply wood to use and think this would look great. could even be a nice foundation to lay carpet, or maybe even a hardwood floor over.
Heath G. is offline   Reply With Quote
Pictures of Aluminum Foam for floors Rick n Modifications, Alterations and Updates 8 06-28-2010 11:46 PM
Aluminum LP tanks? Jeff Peterson Care and Feeding of Molded Fiberglass Trailers 7 02-04-2010 11:05 PM
Fiberglass vs aluminum Donna Smith Problem Solving | Owners Helping Owners 4 03-23-2007 05:48 PM
how to clean aluminum Maggie O. Care and Feeding of Molded Fiberglass Trailers 14 06-18-2006 07:30 AM
Fun with aluminum or a Shelf for our table Legacy Posts Modifications, Alterations and Updates 10 07-23-2003 08:02 PM
