After reading many post/threads here about flooring options I too have embarked on installing the Allure flooring '87 17'
Burro WideBody . My local HD had a sale on Old Country Pine so I picked some up. Donna D. had mentioned the idea of using those kids room foam squares that puzzle piece together as an underlay to add some insulation (My
Burro has none at the moment). I pulled out the old green boat carpet laying it over the assembled foam squares and used it as a template to cut the foam.
I did have a small rotten spot in the floor in the very front that I had to patch. Luckily it wasn't too difficult.
Tonight I hope to get the foam layer in.
My question for y'all is would you have the planks running the length of the camper or would you have the running side to side? I'm asking this due to thinking it may be easier on the install to run them side to side because cutting the vinyl "planks" on the ends to the contour of the wall would be less hassles than cutting the "planks" lengthwise!?!
What are y'alls thoughts on installation plank direction?
Greg
