Flooring choices - Fiberglass RV
Old 05-24-2015, 10:12 AM   #1
Idaho
Flooring choices
I would love to hear what you modifiers have used for flooring and your experiences. I'm considering Pergo or something similar, but also something fun made from linoleum squares. My last choice would be vinyl, but if it is the best choice, I'll use that.
My project is an '80 Scamp 13' which I love.
Cathy
CBinID is offline   Reply With Quote
Old 05-24-2015, 10:28 AM   #2
Dennis mn's Avatar
Last summer, I installed engineered cork flooring in my 19' Scamp. It was left over from my wood shop project, so I had already made the investment. I installed the flooring over the original carpet to provide some sound deadening, and a bit of additional insulation. The jury is still out on how it will wear in Scamp service. After six years in a glucose powered wood shop, I am beginning to see signs of wear. For long term durability, there may be much better or more cost effective floor coverings.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
Old 05-24-2015, 12:52 PM   #3
Cathy
My first choice for wear,durability, ease of installation would be allure plank strip flooring , it's not the least expensive but there's not much sq feet to cover
Mikmay is offline   Reply With Quote
Old 05-24-2015, 01:03 PM   #4
One of the disadvantages to most (but not all) laminate floors it that they are very allergic to water. If each and every spill isn't cleaned up promptly it can lead to major floor damage. Some sealers seem to help, but it's always a concern. There are now some laminate floorings that are designed for kitchens and bath rooms, and that's what I would opt to use in the future.
All that said, I have put down laminate floors in my last 5 FGRS's
Old 05-24-2015, 07:44 PM   #5
Steve_N_Janna's Avatar
Name: Steve and Janna
Trailer: '02 Scamp 13
Given the susceptibility to water damage of the factory OSB / particle board subfloors of most FGRVs, I have three words of advice:
vinyl,
vinyl,
vinyl.
Pick up a nice , high quality vinyl remnant from a flooring shop, cut it to shape - make a template out of paper or cardboard, - lay it down and voila, you have a great moisture barrier that's easy to clean and protects that water sensitive subfloor.
I gave our sub floor a heavy coat of oil based paint to seal it and then laid a thick, self padded vinyl remnant over it. We've been pleased with the results. The only area I glued down was at the entrance. We do keep a small throw rug on the floor, especially in cold weather. The nice part is that when the rug gets really soiled, we just replace it with a new one.
I do like the Pergo and we would have gone with a sheet of it if we could have found a remnant.
Steve_N_Janna is offline   Reply With Quote
Old 05-24-2015, 07:54 PM   #6
Night Sailor's Avatar
Connecticut
Home Depot has some vinyl planking that looks like wood and can be cut with a razor knife. I'm thinking about putting some in my bedroom.
Tow vehicles - choices, choices! frank_a Towing, Hitching, Axles and Running Gear 154 08-21-2013 09:45 AM
New Smaller tow vehicle choices?? Shelley Towing, Hitching, Axles and Running Gear 69 05-19-2007 05:15 AM
So many confusing choices for newbies Frank G. Care and Feeding of Molded Fiberglass Trailers 21 03-16-2007 12:15 AM
Green(er) Towing... fuel choices? Brian B-P Problem Solving | Owners Helping Owners 75 02-01-2007 12:09 AM
