Flooring experiment - Cheap Puzzle Foam Tiles - Fiberglass RV
Old 08-20-2015, 07:18 PM   #1
Just installed temp flooring in a 1987 Lil Bigfoot (13.5ft). It probably won't last too long, depending on the usage but for under $60 (flooring and base boards), it will get me through the rest of the season and hopefully a bit longer. It is puzzle-foam matting, you can pick up almost everywhere. Installed quick, without glue. This tile was wood-grain looking, so it looks pretty good now... time will tell. It's soft and has some insulation factor. It's also easily removable/replaceable in sections. Worth a try. I'll update on it's durability.
John DM is offline   Reply With Quote
Old 08-20-2015, 07:33 PM   #2
Looks very attractive. I've never seen it in a wood-grain design… interesting. Where did you find it? I'll be interested how it performs over time. I'm thinking fine dirt could work its way between the joints, so you might need to take it up periodically to clean underneath. Thanks for sharing.
Old 08-20-2015, 07:47 PM   #3
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Wow!
I have the plane black stuff I put down in the winter for insulation it works great.
Jason
If you think you are to small to make a difference just try sleeping with a mosquito –- The Dally Lama
kirkman is offline   Reply With Quote
Old 08-20-2015, 07:53 PM   #4
In my area (Alberta, Canada), I found it in Costco and Canadian Tire. Costco was only $22 for eight 24"x24" tiles (just enough for my floor), so I bought 2 packs so I had lots for replacements. I love my local Canadian Tire store, but they were double the cost.
Yes, I anticipate dirt and grit getting into the puzzle joints, but it shouldn't be too hard to take it up and clean. It's the price you pay for being cheap . I got a quick install, but will need to spend some time with upkeep.
Venture Products: Best Step - Comfort Flooring
Old 08-20-2015, 08:31 PM   #5
I'm with you. I like simple and inexpensive. It should feel nice underfoot, too.
Here's a direct link: Venture Products Best Step
Old 08-20-2015, 08:34 PM   #6
[QUOTE=kirkman;543395]Wow!
The black (or other solid colour) may not be as attractive looking but will probably wear better since it has a thicker top layer. This wood grain is not that thick so will probably show tears and wear quicker
Old 08-21-2015, 09:30 AM   #7
That is very nice looking and I'll bet very nice to walk on too.
Lee
Captleemo is offline   Reply With Quote
Old 08-21-2015, 09:39 AM   #8
Very nice. I bet its comfortable to walk on too. You may well be starting a trend here. Here is another web site that sells them. Wood Foam Tiles - Faux Wood Foam Floors, Basement Flooring
Lee
A Laundry Experiment Raz General Chat 19 11-21-2013 07:23 PM
Getting the shine back (my experiment) Mark G. Care and Feeding of Molded Fiberglass Trailers 2 02-01-2010 06:28 PM
Flooring trim solution.. cheap and easy! Gina D. Modifications, Alterations and Updates 15 08-24-2009 11:54 PM
Interesting experiment Lex M General Chat 20 02-21-2008 03:13 PM
Flooring: Interlocking PVC Floor Tiles? S Sato Modifications, Alterations and Updates 5 03-13-2006 01:07 PM
